0 members (), 118 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
Norselander showed me this... LINK ...to help me learn frames. What do you guys think of these. Anyone jere ever use them? They sure look nice.
I was looking at frames for my next project in my Classic Trucks mag I get. I would get one of those mags and check out all the ads, there is alot of frames in them. Good luck.
Get busy liv'n or get busy die'n
I'm not an engineer, but that frame doesn't seem to have enough cross bracing. Maybe I'm missing the point. If you are getting a new frame for your project it stands to reason you will be putting a big and powerful motor in it. IMO that frame would not be able to handle that much power. Maybe the transmission crossmember isn't installed untill you specify engine and transmission.
2x6" steel box tubing is pretty stout, but the real question is what gauge is it. If it was 1/4" thick or 3/16" thick then I think it would work cross bracing or no. I would think you'd have to have the transmission crossmember. I don't think a 2 point engine mounting system would ever work.
I think Stacy David from "Trucks" used a frame like that but beefed it up from there. It was on the "Copperhead" 67 Chevy C10 series. He added alot of cross bracing and even a driveshaft loop for rigidity. I think you'll lose all truckability putting a performance/car frame under a pick-up. That's just my opinion though,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
It wasn't the Copperhead. That was an unmolested 67-72 frame.
He did all that cross bracing work to the Hairy Hauler.
Still, pretty cool work he did there.
I wonder when his new show is going air?
Zeke
That would sure be a nice way to go.A bit pricey but it would save a lot of work.The frame on my 55 is in perfect condition,so it was a snap to install independent front suspension,and new rear susp.If I had a vehicle with a bad frame I would definitly look into an aftermarket one.
Chazwel had a good idea to look into the "Classic trucks" magazine adds. There are a lot of frames that will require a lot less work out there that have more mounts and accessories. I see that this frame is very stout, but is missing a lot to be desired the way I look at it.
