8 members (Jethro in Va, 3B, Wingnut68, moparguy, Peggy M, Possum, 1955 1 Series, dt235sd),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Norselander showed me this... LINK ...to help me learn frames. What do you guys think of these. Anyone jere ever use them? They sure look nice. | | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | I was looking at frames for my next project in my Classic Trucks mag I get. I would get one of those mags and check out all the ads, there is alot of frames in them. Good luck.
Get busy liv'n or get busy die'n
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I'm not an engineer, but that frame doesn't seem to have enough cross bracing. Maybe I'm missing the point. If you are getting a new frame for your project it stands to reason you will be putting a big and powerful motor in it. IMO that frame would not be able to handle that much power. Maybe the transmission crossmember isn't installed untill you specify engine and transmission. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | 2x6" steel box tubing is pretty stout, but the real question is what gauge is it. If it was 1/4" thick or 3/16" thick then I think it would work cross bracing or no. I would think you'd have to have the transmission crossmember. I don't think a 2 point engine mounting system would ever work. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think Stacy David from "Trucks" used a frame like that but beefed it up from there. It was on the "Copperhead" 67 Chevy C10 series. He added alot of cross bracing and even a driveshaft loop for rigidity. I think you'll lose all truckability putting a performance/car frame under a pick-up. That's just my opinion though, Scott | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | It wasn't the Copperhead. That was an unmolested 67-72 frame.
He did all that cross bracing work to the Hairy Hauler.
Still, pretty cool work he did there. I wonder when his new show is going air?
Zeke | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | That would sure be a nice way to go.A bit pricey but it would save a lot of work.The frame on my 55 is in perfect condition,so it was a snap to install independent front suspension,and new rear susp.If I had a vehicle with a bad frame I would definitly look into an aftermarket one. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Chazwel had a good idea to look into the "Classic trucks" magazine adds. There are a lot of frames that will require a lot less work out there that have more mounts and accessories. I see that this frame is very stout, but is missing a lot to be desired the way I look at it. | | |
