1 members (RLB), 119 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#214154 08/20/2006 9:50 PM
Apprentice
Apprentice
It's time to replace the old steering box, although I would like to attempt to rebuild it my self. Does anyone know if there is a rebuild kit available or where I can find a reasonable priced replacement. Hans
Any links would be appreciated.
#214155 08/20/2006 11:26 PM
Riding in the Passing Lane
They are easy to rebuild yourself. Minor kits are available at most specialtie suppliers. If the major parts are bad you may wan,t to find a salvage to use for parts or rebuild it. Now would be a good time to think about power steering.
1972 Chevy c10 Cheyenne Super
#214156 08/20/2006 11:27 PM
Is it power assist or manual? I would think any parts house can get parts for either one still.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#214157 08/22/2006 5:53 PM
Hans-
I updated the worn out manual box on my '67 with power steering box. Available from Advance Auto Parts for around $85. It is a bolt in swap and WELL worth the money! A rebuilt pump will run you about the same $. I had several pumps laying around so I did not have that expense - regardless it is still worth the money and makes the truck MUCH easier to drive.
'67 Chevy C-10 283/350
#214158 08/23/2006 1:54 AM
its not a bolt in on a 66,but the adapter kit is about 75 dollars.
64 c10
89 rs
62 econoline
50 ford coupe
#214159 08/23/2006 2:20 AM
A '66 wouln't be integral power, it would have still had the slave cylinder type. Trucks got the integral type box in '67, '68 for 4x4.
Bill Burmeister
