9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman),
93
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I need to do master cylinders on two vehicles. Here are my three assumptions: 1. Dump a rebuild kit out on the table and stare at it. 2. Take a thing called a "hone" and spint it around inside the master cylinder. 3. Take the parts and stick them in there.
Is it any more difficult than that? Tanx!
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | You're not too far off... Like anything, you should inspect the cylinder bore for pits or problems and clean everything with suitable cleaners before re-assembly, but yeah, I think you've about got it. | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I rebuilt mine on the 46 and when I was done did not like the results, so I went ahead and spent a little bit more money and purchased a full replacement. I feel confident that when I hit the brakes it will stop.
Ed | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | Why not let a professional rebuild it for you?
I know I can rebuild a master cylinder, brake cylinder ect... but I dont do it every day, and since my trucks life depends on it... I prefer to let someone who does this sort of thing every day do it... that or buy a new one.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Use brake fluid as a honing oil & keep the cylinder/hone wet as you hone it out. No sweat.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim Bow,
It's only difficult if you have no clue what you are doing. Brakes are one heck of a place for OJT. Good luck.
Stuart | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Rustyrod...thats what scares me most of the time...the ones who do it everyday!! I know what I am doing  | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Jim Bow -
I just rebuilt mine. It kinda scared me of how easy it was. I like doing this kind of work because I feel better knowing how things work.
I plan on testing my brakes completly before I hit the road. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I had my local machine shop do the honing. It was cheap and came out perfect.
I've been using it for about 18 months and it's been rock solid. | | |
