5 members (NJC, cmayna, dt235sd, Hotrod Lincoln, lumbersawyer), 105 guests, and 5 robots.
Topics128,064
Posts1,055,860
Members48,428
#213907 08/17/2006 5:32 PM
I need to do master cylinders on two vehicles.
Here are my three assumptions:
1. Dump a rebuild kit out on the table and stare at it.
2. Take a thing called a "hone" and spint it around inside the master cylinder.
3. Take the parts and stick them in there.
Is it any more difficult than that?
Tanx!
"Happiness equals reality minus expectations" - Tom Magliozzi
#213908 08/17/2006 5:35 PM
You're not too far off... Like anything, you should inspect the cylinder bore for pits or problems and clean everything with suitable cleaners before re-assembly, but yeah, I think you've about got it.
#213909 08/17/2006 6:47 PM
I rebuilt mine on the 46 and when I was done did not like the results, so I went ahead and spent a little bit more money and purchased a full replacement. I feel confident that when I hit the brakes it will stop.
Ed
#213910 08/17/2006 7:53 PM
Why not let a professional rebuild it for you?
I know I can rebuild a master cylinder, brake cylinder ect... but I dont do it every day, and since my trucks life depends on it... I prefer to let someone who does this sort of thing every day do it... that or buy a new one.
Another quality post.
Real Trucks Rattle
#213911 08/17/2006 10:28 PM
Ex Hall Monitor
Ex Hall Monitor
Use brake fluid as a honing oil & keep the cylinder/hone wet as you hone it out. No sweat.
#213912 08/17/2006 11:14 PM
Jim Bow,
It's only difficult if you have no clue what you are doing. Brakes are one heck of a place for OJT. Good luck.
Stuart
#213913 08/18/2006 1:33 AM
Rustyrod...thats what scares me most of the time...the ones who do it everyday!! I know what I am doing grin
#213914 08/19/2006 12:37 AM
Jim Bow -
I just rebuilt mine. It kinda scared me of how easy it was. I like doing this kind of work because I feel better knowing how things work.
I plan on testing my brakes completly before I hit the road.
#213915 08/19/2006 2:29 AM
I
I Offline
I had my local machine shop do the honing. It was cheap and came out perfect.
I've been using it for about 18 months and it's been rock solid.
