6 members (JW51, 55shaker, moparguy, Cosmo, Gdads51, 1 invisible), 108 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#213459 08/10/2006 2:07 AM
I
I Offline
We learn something cool today. Grill bars come marked from the factory. I dont know how many others were aware of it, but they are. If you look on the right hand back side, near the center, you will see little notches. There are two in the second bar, three in the third bar, and four in the fourth one. These notches are on both the front half and the back half of the bar. The top and bottom bars can only go in one place. Make sense that the factory needed some way to keep it straight at assembly. I've looked at several of our big and little trucks, they all have them. Also did you know there are nearly 140 rivits/bolts that hold a grill together. Isn't any wonder that they went to a differnt grill on the 54 and up. Just thought I would pass this along to the masses.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#213460 08/10/2006 2:34 AM
Don't brag too fast about those '54 Chevy Grilles. Try taking one out of a '54 Chevy COE. I had to remove somewhere between 40-50 screws to get those things out, for painting.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#213461 08/10/2006 4:36 AM
Quote
I'll be there soon enough trying to make one out of two, LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#213462 08/10/2006 5:17 AM
I
I Offline
Scott we a pretty nice grill from the 54 truck. Only got one little ding in it.
Jeff
1953 3/4-ton
#213463 08/10/2006 5:33 AM
Quote
Don't brag too fast about those '54 Chevy Grilles. I had to remove somewhere between 40-50 screws to get those things out, for painting.
Yep My 54 Plymouth has the same problem.
I guess in 1954 the designers had nothing to do but make the grills hard to fix or replace. grin
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
