| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm putting together my 63 K20 drivetrain in hopes of getting it completely done before starting the body work. Two years after she got torn apart and pushed off to the side to work on other projects or whatever, tonight I fired it up. That crisp sound of a 468 through 2 1/2 inch dual exhaust just gets your blood flowing. It wasn't a total success, the fuel pump dried out from sitting and now leaks a little, but that's just a minor set back. At least now I'm taking two steps forward with every step back. It's good to see progress once in a while. Scott | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | 48 big... did you crank it up at the traditional 2am (0200), so that your neighbors will really appreciate your hobby?
There isnt much of anything more motivating than hearing the engine crank up for the first time (or in a long time).
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by Rusty Rod: 48 big... did you crank it up at the traditional 2am (0200), so that your neighbors will really appreciate your hobby?
Thanks for the reply Rusty, Fortunately, I don't have any neighbors so I can go out there anytime of night and fire one off, in my skivies even (Don't even try to picture that). I might get a cow bellerin' back at me, but little do they know they will be on my dinner plate one day. I do like being out in the boonies, Scott | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Good job, soon you'll have time for a couple more wife projects, the n you can get down to the serious work on that COE. | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | Do you have any pictures of the motor?
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Yeah, but it's an older one. I took it as I was putting it in. This is what it looked like then. Now my air cleaner is painted, brakes and trans line plumbed, radiator, etc. I got the fuel pump today so I'll be able to run it a little longer and get the trans and P/S topped off. Then after it cools off outside, I'm going to wash everything off to get rid of the shop dust that's on everything. I'll take a more up-to-date picture soon, Scott | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | about how much power would the 468 have
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm not sure, I bought the truck because it had this fresh engine in it. It can light up 38" Swampers (you know how soft they are) like they are spinning on grease. It was built as a pulling truck so I'm just guessing at around 400 h.p. We have Titans at work rated at 305 h.p. and it pulls alot harder than they do. I once pulled an old 2 ton AD boom truck up and out of a brush patch so I could rob it of it's wheels and other parts. Come to find out, the cable from the boom was still attached to some big chunk of iron and there was a 3-4" tree growing through the frame, not to mention all six of it's tires were sunk into the ground. She pulled it up and out of it's ruts, uprooted the tree and drug that iron plate about 20'. This truck is an animal, that's why I'm rebuilding it,LOL, Scott | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | have you got any pictures of the truck
