2 members (farmallb, 2-Ton),
165
Mod | | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Well, after a year of lurking around the site, I have finally acquired my own stovebolt (2 of them in fact!).
I was able to bring home a '57 GMC one-ton (9' box) pickup (missing front sheetmetal and drivetrain, but has a beautiful, almost rust free cab and box) as well as a '59 Chevy 3/4 ton (8' box) pickup. Both trucks are stepsides.
Oh yeah, 2 trucks delivered from 60 miles away for $ 1300.00!
I'm planning on moving the front sheet metal from the '59 onto the '57 (love the quad headlights!)
I finally consider myself a true-blue stovebolter!
Pics coming soon!
Photo | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Originally posted by Photo: .....love the quad headlights! A Bolter after my own heart. Cliff59 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | photo - you'll find when you do that swap that the threaded mounting holes for the hood hinges on the 57 cab don't quite fit the 59 hinges - oval the hinge holes carefully and you can make it work, but you might have a few problems with the hood fit - also you'll find that the 59 frame is about 1.5-2" longer than the 57, because of that little gravel pan below the 59 grill - will need to make some type of extensions there on the 57 or the stock bumper brackets won't work cuz the bumper won't clear that pan good luck tho, it can work!! Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Welcome to the 'bolt and good luck on your project(s).
| | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Thanks for the replys guys!
Red58; Which holes do not match up? I'm planning on using the '59 Inner and outer fenders with the '57 cab (it's in better shape!). Is it the holes on the firewall? I was under the inpression that all cabs were identical from late '55 to '59!
As far as the gravel pan, etc..... I plan on using this sheet metal on a late model (hopefully a '98 or later dually diesel) chassis and running gear. There will be a bunch of fabrication involved in mounting the cab and bed on the newer frame, a little more won't hurt?
Hey Grigg, how's your diesel project coming along?
Photo | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, you'll have some mods to make it all fit on the late model chassis! notice that the rad core support mounts align the front sheet metal to the cab, critical
the hood mount holes in the firewall [with cage nuts behind] appear the same all years, but in 58 the hinges underwent a redesign, and in order to get the 58/9 hinges to bolt into those holes on the earlier cab you have to hog out the holes in the hinges, and the earlier hinges won't work w/ the later hood/inners - I haven't measured, but I think they moved those firewall cage nuts a bit in 58 as the firewall stamping changed in a few details in 58
Bill | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I know 1 person that would kill for that 9 foot bed if you end up using a shorter one. | | |
