3 members (2-Ton, Hotrod Lincoln, 1 invisible),
86
Mod | | | Forums66 Topics128,165 Posts1,056,988 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Hiyas peoples... Dad installed his 12v ammeter into the gauge face on the '53 3100 today: image of the gauges for \'53 chevy 3100 - no glass Now he is looking for something to use for a gasket between the housing and the gauge glass... and I was wondering about ways to clean up the face as much as possible before reassembly. So, what suggestions and methods do you folks have? -W | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Woog, I've never found anything to clean or restore the faces of those guages. I've tried about everything I could think of on old faces I've had, Laquer thinner removes the paint, enamel reducer, 409, Fantastic, Citrus cleaners, GooGone, Rubbing alcohol, you name it. Usually the faces are faded and the silkscreened numbers almost appear to aquire surface rust. Maybe someone else has come across something. As far as the gasket, if you don't want to order what the suppliers offer, the lock strip used to repair window screens works well. It's usually available at any hardware store in a variety of sizes.
Bob | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Hi, I had the same problem years ago. I found a classic parts supplier that had dash gauge decals. I was skeptical at first about what the quality would be like but I ordered some and installed them over 10 years ago. They are great! Look original, stick down nicely and are still perfect today. Take a look at www.fillingstation.com browse catalog for 'decals - truck gauge' Might be a good alternative for you.
1948 AD Pickup
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I just used a big (about 4") o-ring to seal mine. A thin one works best.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | While you have the guage cluster out why not paint the inside of the gauge cluster bucket (for lack of term) with a white enamel? This will give your cluster better elumination at night. Tom | | | | | Joined: Jun 2006 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 13 | my brother use to own a business installing glass in cars. he had some kind of cleaners that could take out scratches on glass. you might try an auto glass place in your area. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Thanks everyone. brjr51 - ah. I'm glad you posted... I'll be sure not to do any of that stuff then. 4ontheFloor - yeah dad and I were thinking we'd hit the hardware store and see what they had in the rubber o ring department. We have a really good hardware store in town with a huge plumbing section... we figure some vendor has the right gasket thing, but as pop has said many times: 'this is no show truck'. 235 Fat Fenders - yeah I was noticing it is kinda rusty there... but that is Papa's truck so... it is whatever he wants to do. littlebuddie - I knew about filling station, but I didn't know about the gauge decals. Thanks for the part source tip. -W | | | | | Joined: Jul 2004 Posts: 2,990 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,990 | Jim Carter has the gauge decals, too. Have not tried them yet, but I plan to when I replace the speedometer in my '47 with the one Grigg sold me. | | | | | Joined: Jul 2005 Posts: 88 Member | | Member Joined: Jul 2005 Posts: 88 | I used Jim Carter's faces on my gauges...very nice, fit perfect, and most importantly, matched everything else identically. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Thanks everyone.
Do ya have to totally disassemble the gauges to put the faces on there? or onyl partially... or is it just easier and simpler that way?
-W | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | woogeroo,as long as the cluster is out the decals slide under the pointer and do look original.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | cool.
Thanks, Slow..Rider.
-W | | |
