1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | You know how your trouble lite gets hot You can cool it down by puting one of those small mini flourescnt bulbs in they stay cool an are bright enough to work with . | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 |
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | How resistant to damage from being dropped are they?
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I still have a scrare on my arm from the trouble light burning me. My arm was way down in the engine compartment and the light fell against my arm.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | | | | | | Joined: Jan 2006 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 67 | i would think that the ones made of plastic-like material are less prone to breaking than a regular glass bulb.
red (mostly) 1963 chevy shortbed stepside
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I may be working on antique trucks but I like modern tools. I use a 12" flourescent drop- light. One of those exploding types started a fire in a friends shop years ago. | | | | | Joined: Jan 2003 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 32 | I seem to only drop the the trouble lite when I have both hands where I can't let go. The light falls and the bulb goes out. I did finally buy flourescent drop light and it sure is a lot cooler and just as bright. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I did the same thing,got tired of replacing bulbs in the old one and getting burned.Bought a flourescent one from Home Depot.It is cool,and has been dropped several times and keeps on working.Prive was around $20. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Another great lighting source is those rope lights, the kind you see as Christmas decorations. A string of bulbs in a plastic flexible tube. Used them a lot in airplanes especially when working in the tail cones. Wall to wall light. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | If you like the old incandescent bulbs, they make a special one for use in the shop that doesn't break when you drop it. I used to break the filiment in bulbs all the time, with the new bulbs they last forever.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Two things that I have found are:
#1 that the florescent bulbs used in the trouble light are, in addition to being cooler, much more resistant to braking when dropped.
#2 the plastic trouble lights let more light out through the back side of the shield which shines into your eyes making it hard to see what you are working on | | |
