4 members (Shaffer's1950, BC59, homer52, UtahYork), 98 guests, and 2 robots.
Topics128,038
Posts1,055,590
#212051 07/18/2006 8:33 PM
You know how your trouble lite gets hot You can cool it down by puting one of those small mini flourescnt bulbs in they stay cool an are bright enough to work with .
#212052 07/18/2006 8:49 PM
thanks for the tip....
Another quality post.
Real Trucks Rattle
#212053 07/18/2006 9:49 PM
Ex Hall Monitor
Ex Hall Monitor
How resistant to damage from being dropped are they?
#212054 07/18/2006 9:57 PM
I still have a scrare on my arm from the trouble light burning me. My arm was way down in the engine compartment and the light fell against my arm.
38 original
48 panel
59 stepside
46 in the back forty
#212055 07/19/2006 12:54 AM
I havn't Drop it yet
#212056 07/19/2006 4:35 AM
i would think that the ones made of plastic-like material are less prone to breaking than a regular glass bulb.
red (mostly) 1963 chevy shortbed stepside
#212057 07/19/2006 5:41 AM
I may be working on antique trucks but I like modern tools. I use a 12" flourescent drop- light. One of those exploding types started a fire in a friends shop years ago.
#212058 07/19/2006 5:48 AM
I seem to only drop the the trouble lite when I have both hands where I can't let go. The light falls and the bulb goes out. I did finally buy flourescent drop light and it sure is a lot cooler and just as bright.
#212059 07/19/2006 12:53 PM
I did the same thing,got tired of replacing bulbs in the old one and getting burned.Bought a flourescent one from Home Depot.It is cool,and has been dropped several times and keeps on working.Prive was around $20.
#212060 07/19/2006 4:56 PM
Another great lighting source is those rope lights, the kind you see as Christmas decorations. A string of bulbs in a plastic flexible tube. Used them a lot in airplanes especially when working in the tail cones. Wall to wall light.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#212061 07/19/2006 5:04 PM
If you like the old incandescent bulbs, they make a special one for use in the shop that doesn't break when you drop it. I used to break the filiment in bulbs all the time, with the new bulbs they last forever.
#212062 07/19/2006 5:05 PM
Two things that I have found are:
#1 that the florescent bulbs used in the trouble light are, in addition to being cooler, much more resistant to braking when dropped.
#2 the plastic trouble lights let more light out through the back side of the shield which shines into your eyes making it hard to see what you are working on
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
