1 members (NofoolN),
125
Mod | | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Uhhhh....bullet holes? Has Skippy been around this truck?
Bill Burmeister | | | | | | Anonymous Unregistered | | Anonymous Unregistered | sweet truck,you should get a kevlar helmet,just to be safe. :p | | | | | | Anonymous Unregistered | | Anonymous Unregistered | | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | [Ideas? Please help me out!]
Fer starters, try put'in the cab on the OTHER end. ROTFLOL... Seriously, I think you've got a nice project there. Hope you get it together quickly so's you can enjoy the drivin part.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Originally posted by Rance: Fer starters, try put'in the cab on the OTHER end.  :rolleyes: :p Does the 216 run? | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | ph32,
are you still in Korea?
I am not near the expert that others are on here...but my 46 is my second art deco..my first one was too much for me. If I could turn back the clock,I would have spent more money on a better truck up front. My second one, I did just that.
With that said, what do you want for a final product?
You are looking at $15-1800 for a box unless you do a flatbed.( I did not see a box)
$250 per door unless you can do a re-skin yourself. My desert door was $150 plus 100 for shipping.
$150 for wiring harness.
$400 for tires.
There is a pile of money you will spend on other parts regardless of what you buy. I just spent$300 on do-dads for the firewall like grommets, hood corners, fender gaskets, etc etc.
Your truck is not hopeless by a long shot, but wow...as you say, there is a lot of work to do!
Have you thought about another 46 for parts and make one good one out of two? Another $2000 truck might give you an easier platform to start with....you have some great parts.
Do you own or have access to a mig welder?
If only you were near Mn, I know of a rolling chassis you could buy that would put you on your way to a finished truck real quick like! | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | You've got a lot of work there, your caption on the frame says it's no good, looks to me like a little sand blasting would probably bring it up to like new. My 46 wasn't quite as bad put yours looks restorable. Good luck and keep us up to date on progress. Bob T | | | | | Joined: Jul 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 24 | Wow... an intact 216. Even has the 6-volt generator! Definitely keep that! As 46 noted, finding an original bed won't be cheap or easy. The flatbed is a great idea. I've seen a number of Art Deco-era pickups sporting a flattie or stakebed. I'd say a nice oak bed with matching oak stakes and flats (stained and varnished, of course) would look absolutely breathtaking with a nice, deep coat of bright yellow paint! Polished stainless hardware, of course. I'd go with reproduction steel wheels and hubcaps too. I know they're out there. Looks like everything else is pretty straight and, aside from some surface rust, solid. Except the buckshot in the cab. Why would anyone do that??? Brother\'s Trucks Dixie Truck Works Try those guys out. Brother's doesn't specialize in your year, but they do have some pretty cool stuff and their staff is awesome. I've used 'em extensively for getting my '66 GMC back on the road.
If a 'truck' is only used to haul butts to the mall, then it's not a truck - it's a car with a roadster trunk.
Old, rusty and ugly - might be me or my fleet. You decide!
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | on the back window, it looks like a lefthand shooter jerking the trigger. lots of work but it should keep you off the streets for a while.
tony | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Thanks-i plan on takin my time. Hot rod direction. Yes i am still in Korea, goin back in a week, then a year from now we will return here for good. Truck is in a storage bay right now. The bullet holes are probably from a farmers fild target practice. Later i guess someone tried to fix it but found it to be too much.. I will keep yall posted on her. Flatbed definately! I think oak or walnut. maybe metal but i doubt that.I will talk too ya soon.
Oh the 216 is dead right now.. | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | Anything is repairable depending on how much you want to spend. Have a plan and go for it. You have a great starting point. Maybe go rat rod with it and leave the bullet holes. Real ones look better than those sticker ones. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Originally posted by packhorse32: Here is my truck guys- lots of work to do man lots of work to do! Ideas? Please help me out! cab5 That's a nice lookin' running gear, but the axles look a little close together don't you think?
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | yeah thats one way of doin it!!! Ratrod, and flat bed....bullet holes stay... i kinda like that idea. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | How about this; rat rod-yellow primer with red oxide flames/scallops-oak flatbed-and an Olds Rocket or Buick Nailhead with fenderwell headers.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I love the Idea of putting the cab ot the back of the frame.That should be a real head turner. | | | | | Joined: Jul 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 24 | Hm... dead 216.
Might I suggest a Fenton, Sanderson, Clifford, or Offenhouser-equipped 302 GMC?
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | How about the aforementioned flatbed,a set of front hubs from a 1 ton,a later rear with 3.73 gears,budd wheels(alloys if you can swing it),a Saginaw 4 speed with an overdrive installed,and a built 302 GMC six. Maybe twin stacks.It'd be cool,useful,fun and you would never see another truck like yours. That's how I'd do it... Speed | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Your wife is thinking "what the #Eck is this POS doing in MY yard!!!!! I can see it in her eyes.
anyway... it looks like a great winter project... you can buy a repopped bed for it... or flatbed it.
| | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | yeah-thats Gator-she was expecting the worse and we sure got what she thought was the worst-but the truck is exactly what i want....I want to start with that junk and build up. That way im not tearing apart and putting back together. I may paint the cab as i keep lookin for frame and engine. She will be sweet when shes done! | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | I agree with Kruizeag, it would be interesting to leave the bullet holes. Maybe after painting they could be filled in (leave them deep) with black silicone, to keep the weather out.
Keep us informed on any progress.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Nice pattern for a BB gun  What is wrong with the frame? Is the bottom part of the channel rusted away somewhere? I love the shot of the grill, that is going to look proud someday! Good luck! Rick | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | I think that patterns from a 22 short, frame has holes rusted through it... would have to be braised and i dont consider that safe... | | |
