0 members (),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | My 51's rear brake lights are hard to see in the daylight. What have you done to make them safer?
I'm tempted to change to another type of light...but thought I'd ask here before doing so.
I've got reflective aluminium in the fixture right now...it helped a bit.
Can't find an LED retrofit.
Help!! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I found a led retro that worked in my truck but haven' seen anything that would work in yours. Tried all the fixes you did Hot litz make a led that fits in the box rail end that I was considering wiring to the stop light $75 but found the 39 ford lens I needed first. Will check out where I got mine to see if they make somthing you can use. I tried stronger bulbs and the led bulbs with about 10 leds in them that refit the regular bulbs. not good | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | | | | | | Joined: Jun 2006 Posts: 41 Member | | Member Joined: Jun 2006 Posts: 41 | Any chance you just have a bad ground and/or bad wiring? One of my front parking lamps was dim until I discovered it wasn't grounded properly...
Get some good information or help? Donate to the site and keep it alive for all to enjoy!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you have a 6v system, here are some 6v LED bulbs. However, the easier and cheaper thing to do is try to obtain a better ground (as suggested by 1963C20). Clean the housing screw-to-body attachment points and apply Kopr-Shield ; or, run a ground wire from the frame to the lamp housing. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | 6 V LEDs that don't require a spade type socket.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | If you don't want to go to LEDs you might check out Ron Francis Wiring. They have extra bright incondesent bulbs for your existing tail lights. I have switched to these and the difference is substantial. They aren't cheap, about 4 bucks, but I think they are worth it. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Try this place LEDtronics | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Billybolt,
That's a great link.
Tim | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Try speedway motors- They've got 47-53 LED OEM taillights for 30/side including the housing.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | 1) Check your Grounds. I am running 1154's in my 6v tail ligs and they work like champs.
2) Verify that you're running the correct bulbs. 12v bulbs don't work so hot.
3) Check out that link that Tiny posted. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Here's the way we do tailights on the AD's and have had very good results. First we clean a spot on the back(side opposite the lens) so we can put a dot of brass connecting the socket to the tailight housing, this is very important because you can develope a bad connection in the factory crimp joint. Next we blast the inside with some very fine media and prime with etching primer and then use chrome spray paint applied in thin coats for two or three times, making the area behind and around the buld just like a mirror. Spray the bracket with aluminum paint to retard rusting and give a good ground and, after thoroughly dry,paint factory black or body color if desired. Now chase threads on the cage nuts in the stake pocket and bolt on the bracket with NEW lockwashers that will bite into the bracket. Ground the bed to the frame, the engine to the body and frame. Now with the high intensity bulbs offered by several suppliers you will have lights that can be seen day or night.
Evan
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | thekid1950, Had the exact sme problem with my '49. Almost getting rear-ended by a cop brought it to my attention. Ran ground cable from the battery to the engine. Also ran a ground strap from the cab to the engine and the cab to the frame. After that my taillights looked almost like brake lights and the brake lights would almost blind you!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Might as well toss in my $.03. My project truck is not a stock restoration so I went a little overboard and cooked up some LED's that leave NO doubt that the brakes have been applied.
The local Tractor supply had all the parts and the fabrication time was a couple hours.
Supplies included a (2) 4" LED truck replacement light assemblies and (2) 4" PVC pipe caps. The caps were routed out on the drill press with a small grinding wheel until the Rubber-mounted LED fit tight. Some flat stock made the bracket and I even added LED turn signals.
Take a look at my finished product in my album. Might be just the ticket and if you're a purist, you have my deepest apologies. If you're interested I can give you some suggestions on how to make it a 1 hour project! | | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | Thanks for all the tips & suggestions. I'll go to work on them.
My system is 12 volt.
This forum is a great place to share knowledge. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | By the way I also put in an electronic flasher $14.00 Not because of my LED taillights, but because my lights were flashing slow with or without my LED's | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Here's a link to 'halogen' bulbs. Australian manufacture but they have a US dealer. http://www.classicandvintagebulbs.com/ | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion.....to slow down an electronic flasher simply install a conventional socket/bulb somewhere in the line between the flasher and the LED bulb. The LED's require very little juice and the extra draw will slow down the flasher to a more normal rate. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | bITE THE BULLET and spend the $ at speedway for the led. Tried all other avenues and they didn't work. Hi intensity bulbs, led bulbs, new wiring. finally bought the right stuff and am very happy. Thanks for the note kid. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Cheep-n-eezy; Get a panel of those muffin tins from the store;cut out a couple of 'em and poke a hole in the center of each one. Take the bulbs outta your taillights,wipe the inside of the lenses off really clean,or run 'em through the dishwasher.Slip the muffin tins over the light sockets and form 'em the best you can to the inside of the taillight housings. Put everything back together and wipe a little silicone grease over the gaskets to be sure no dirt can get inside.Wouldn't hurt to pack some sealant around the wiring at the point where the wires go into the housings. Time spent-about half an hour. Money spent-about a buck. Speed | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | If the shiney aluminum foil won't work, that won't either. I tried all that stuff. | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Hey, Kid,
I agree with the guys who think you have a ground problem. I did away with all my ground problems by running a length of insulated 10 gauge single-strand housing wire (the stiff stuff that's cheap) all the way around the chassis. Everywhere I needed a ground I tapped into it, even running secondary grounds from it up into the cab. You can tape or put 'pookie' over the attachment points to prevent deterioration. Then forget about individual ground problems. | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Just saw that LED clusters on Harbor Freight (item 93263 www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search) are about $11. This could probably be stuck inside your existing houseing. However, I'm sure it only replaces a single filament bulb. Regularly $19, on sale until 8/2/06 for $11. And no, I don'w work for them.
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I tried checking out that link, it came up as a non-existing part number. Couldn't find it in the site either. Are you sure about the part number?
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Well, just go straight to www.harborfreight.com . Then under "Find Item Number:" on the left, enter '93263' and click Go. That should do it. It'll show as the $19 price but they emailed me a coupon (upc code 76305390, mkt Code=78026282375). $19 price $13 Sale $ 2 Coupon $11 Final Rance
| | | | | Joined: Dec 2002 Posts: 3,444 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,444 | I bought a set of inexpensive trailer lights, I swapped the new parts into my "stock" repopped tail light housings... i have brighter lights, and the turnsignal is inside now... I didnt ground the bed to the frame tho... so I'll do that too.
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | JC Whitney also has halogen bulbs that fit right in with no problem. | | |
