4 members (KEVINSKI, C10 - C90 Bill, Peggy M, JW51), 54 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#211406 07/09/2006 7:01 AM
Apprentice
Apprentice
Does anyone know what the color of 66 c10 1/2t frame should be? Hans
#211407 07/09/2006 1:34 PM
rust color grin - if the factory used anything it woulda been a semi-gloss black called "chassis black"
#211408 07/09/2006 2:51 PM
1 Offline
I read somewhere that GM's chassis black is no longer available. PPG ST1202 is the correct color and sheen as a replacement, and Eastwood sells it also.
Get some good information or help? Donate to the site and keep it alive for all to enjoy!
#211409 07/09/2006 8:40 PM
Socket Breaker
Socket Breaker
Quote
Originally posted by red58:
rust color grin
that is the color of the frame on my '65.
rust.
grin
-W
#211410 07/09/2006 8:49 PM
I used "wrought iron black",it looks the same to me, that semigloss kind of appearance.
#211411 07/09/2006 8:52 PM
V
V Offline
Underhood and frame color is usually approximated by a 60 percent gloss black. This is a common color available to a powdercoating company.
Frames were not painted from the factory. You can paint it whatever color suits you.
#211412 07/09/2006 8:53 PM
I used John Deere black, it is very durable,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#211413 07/09/2006 10:38 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
I'm certanly no expert but I'd have to agree. In all the vehicles I've been under I've never seen a factory painted frame.
#211414 07/10/2006 1:37 AM
I agree with the others, the correct frame color (stock) is rust. Mine is a lovely mixture of red clay,rust, and oil/grease in places. If I were to do a full frame-off resto, I would probably paint it black as others have also suggested.
58 Fleetside, 235, "The Old Buckin' Bronco"
#211415 07/10/2006 1:43 AM
Apprentice
Apprentice
I just finished putting por 15 on my frame and I am going to paint over it with por 15 chassis black.
#211416 07/10/2006 2:46 AM
PPG primer DP90 is very tough and looks good, has just the right amount of shine, or lack of shine as it may be.
We use it all the time as a finish coat with great results.
1952 Chevrolet 3800 pickup
---All pictures---
#211417 07/10/2006 11:02 AM
The only part of my 65's frame that had paint was the cross members at the rear and trans. It did have undercoating on the front around the wheel wells. I am not restoring mine, so I am painting the frame Rustoleum satin black.
1965 Chevy C-10 Longbed Stepside
#211418 07/12/2006 4:17 PM
GM used a very thin coat of black dipping paint Primer and finish coat all in one for most chassis. It was mostly solvent that evaporated in the environmentally unconcious era.
Gord
#211419 07/12/2006 4:55 PM
I used a 2 part epoxy primer and black acrylic with hardener. I like the outcome but would suggest using a black primer. Pics below
Dan
http://community.webshots.com/photo/512683224/2951450480071274430qeOjmO
#211420 07/12/2006 8:21 PM
Dan, nice pictures of the frame, but I really like the rotary frame holder. Did you extend the engine stand height any to allow the running board brackets to clear the floor or are they tall enought already? Stovebolters are a very inventive breed. cool grin grin
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#211421 07/13/2006 2:30 PM
41
I put a couple of pallets underneath to gain the couple of inches to clear running board brackets. It was quite stable. I still had one of my boys help me roll.
Dan
#211422 07/13/2006 10:29 PM
Dan, thanks for the info, I have a couple of engine stands and this would be a good solution to having to keep turning the frame when working on it.
Kirk
