0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Last year I parted a '62, and grabbed the whole front suspension. I've since cleaned it all up, had it sand-blasted, and repainted it.
2 weekends ago I installed new ball joints and A-arm shafts, and dropped the old suspension out of my '60.
This weekend I got the whole front frame cleaned, degreased, and de-rusted. Then I got it painted, and got the newly rebuilt front suspension in! It looks AWESOME!
The only problem that I had (aside from fact that my friend the crack-head stole $500 worth of tools out of my garage) is that the spindle bolts that Classic Parts sent were the wrong thread. Other than that, by the way, they did a great job.
I took some pics, I'll send them to my gallery when I get a chance.
Brian | | | | | | Anonymous Unregistered | | Anonymous Unregistered | That would make him a "former" friend in these parts.
Sounds like progress is being made. Looking forward to the pictures. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | sounds cool man, too bad about the tools. is the 62 front end a torsion bar set up? or is it coil springs? I have been interested in putting a coil spring setup in my 61. jow hard is the swap? can't wait to see the pics.
kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Kyle, Torsion bars were 60-62. The 62 front end is identical except for the spindles (which are currently for sale  ) And Houston, you're right. I was speaking in the past tense about the work, and so he was "friend." Speaking in the present tense, he WAS friend. Unless some day he straightens up and decides to replace them. Brian | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I pulled out my carpet and installed laminated flooring... i only messed up twice... i let the first couple of courses scooted out from the wall and I didnt notice it.. and cut the last board too short... i'll put some spacers behind the base boards to cover the gap...
I also weeded around my trees and rebuilt the water bowls around them...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I got started sorting parts/needs for finishing/detailing a buddies panel - looks like I'll hafta rip everything out under the dash and do it over - wiring out the wrong holes, crummy gas pedal setup, aftermarket heat/air unit preventing install of the glovebox, messy firewall cover also got a runnin start on a gazebo to use up a bunch of "historical" material I salvaged from a hundred year old house some time back - too hot for this old boy in the sun, so it's a late evening job now, a place to sit and sip some of Dr Bill\'s elixir when it's done Bill | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Finished paint striping the Interior and exterior and presser washed the Interior and exterior and the under belly it is all clean and bright aluminium time to acid wash and Alodine and two part prime lots of work. And picked up my two pieces of glass $750.00 Good thing you can’t take it with you Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I worked on my rig on the 4th, got the old front crossmember out, some stuff cleaned up, painted some rally wheels, got one mounted, need to take them in for balancing. undercoated some of the rear floor area underneath. brian | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | They held the first annual Unfinished Nationals car show up here over the weekend. Great venue and about 60 cars showed. However most ere 'finished'. The two only unfinished I liked were a 34 Austin roadster - just four fenders and a body - and a late 40s Mercury panel truck. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | ouch friend??? i don't think so....
good job brian
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You are not alone-I got a lotta ex-friends who got on the meth-don't need them around anymore either. One close buddy from high school was making $100K a yr(his own company) until the wheels fell off, now everything he owns will fit in a duffle bag & he lives w/his mom & dad @38 y/o,,his kids are scared of him,,brian | | |
