2 members (Gray_Ghost, BC59), 173 guests, and 2 robots.
Topics128,079
Posts1,056,058
Members48,433
#211119 07/03/2006 5:17 PM
Last year I parted a '62, and grabbed the whole front suspension. I've since cleaned it all up, had it sand-blasted, and repainted it.
2 weekends ago I installed new ball joints and A-arm shafts, and dropped the old suspension out of my '60.
This weekend I got the whole front frame cleaned, degreased, and de-rusted. Then I got it painted, and got the newly rebuilt front suspension in! It looks AWESOME!
The only problem that I had (aside from fact that my friend the crack-head stole $500 worth of tools out of my garage) is that the spindle bolts that Classic Parts sent were the wrong thread. Other than that, by the way, they did a great job.
I took some pics, I'll send them to my gallery when I get a chance.
Brian
#211120 07/03/2006 6:13 PM
Anonymous
Unregistered
Anonymous
Unregistered
That would make him a "former" friend in these parts.
Sounds like progress is being made. Looking forward to the pictures.
#211121 07/03/2006 7:42 PM
sounds cool man, too bad about the tools. is the 62 front end a torsion bar set up? or is it coil springs? I have been interested in putting a coil spring setup in my 61. jow hard is the swap? can't wait to see the pics.
kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#211122 07/03/2006 7:45 PM
Kyle,
Torsion bars were 60-62. The 62 front end is identical except for the spindles (which are currently for sale smile )
And Houston, you're right. I was speaking in the past tense about the work, and so he was "friend." Speaking in the present tense, he WAS friend. Unless some day he straightens up and decides to replace them.
Brian
#211123 07/03/2006 8:35 PM
I pulled out my carpet and installed laminated flooring... i only messed up twice... i let the first couple of courses scooted out from the wall and I didnt notice it.. and cut the last board too short... i'll put some spacers behind the base boards to cover the gap...
I also weeded around my trees and rebuilt the water bowls around them...
Another quality post.
Real Trucks Rattle
#211124 07/03/2006 9:10 PM
I got started sorting parts/needs for finishing/detailing a buddies panel - looks like I'll hafta rip everything out under the dash and do it over - wiring out the wrong holes, crummy gas pedal setup, aftermarket heat/air unit preventing install of the glovebox, messy firewall cover frown
also got a runnin start on a gazebo to use up a bunch of "historical" material I salvaged from a hundred year old house some time back - too hot for this old boy in the sun, so it's a late evening job now, a place to sit and sip some of Dr Bill\'s elixir when it's done grin
#211125 07/06/2006 9:25 AM
Finished paint striping the Interior and exterior and presser washed the Interior and exterior and the under belly it is all clean and bright aluminium time to acid wash and Alodine and two part prime lots of work. And picked up my two pieces of glass $750.00
Good thing you can’t take it with you
Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#211126 07/06/2006 2:09 PM
I worked on my rig on the 4th, got the old front crossmember out, some stuff cleaned up, painted some rally wheels, got one mounted, need to take them in for balancing. undercoated some of the rear floor area underneath. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#211127 07/06/2006 2:34 PM
They held the first annual Unfinished Nationals car show up here over the weekend. Great venue and about 60 cars showed. However most ere 'finished'. The two only unfinished I liked were a 34 Austin roadster - just four fenders and a body - and a late 40s Mercury panel truck.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#211128 07/06/2006 2:55 PM
ouch
friend???
i don't think so....
good job brian
Jim & Caroline
#211129 07/07/2006 3:17 PM
You are not alone-I got a lotta ex-friends who got on the meth-don't need them around anymore either. One close buddy from high school was making $100K a yr(his own company) until the wheels fell off, now everything he owns will fit in a duffle bag & he lives w/his mom & dad @38 y/o,,his kids are scared of him,,brian
