0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 38 New Guy | | New Guy Joined: Dec 2005 Posts: 38 | Stupid question I know, but I am just looking for an approximate so I can figure out what size truck I need to tow it from place to place safely.
1961 C-20, 2x4, Long wheel base I think.
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off" - General Colin Powell
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Figure on about 3900-4200 lbs. depending on what bed it has and what other equipment (4-speed,V-8, etc.). Also factor in other thing suchas extra parts that may be included with it. You may consider renting a trailer from U-Haul if you don't have one already, their prices are reasonable. I towed my '55 home frome Geogia with a U-Haul trailer and an '88 3/4 ton K-2500, did fine.
Bill Burmeister | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | There is a thread in the Greasy Spoon called, "wanna know what your vehicle weighs".... I hope it helps. Beware...several methods are non-conventional MexicoSab  | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I had a 66 once and it was 4400 lb's ,it was 3/4 ton long box ,fleet side. my 53 1/2 ton short stepside box weighs 3400 lbs. Much better mileage, lol. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Once loaded take it to a truck stop and get it "officially" weighed. Should be plenty of place's around your area. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | But if he wants to know what it weighs so that he can select a truck to pull it, why would he weigh it after it was loaded? | | | | | Joined: Dec 2005 Posts: 38 New Guy | | New Guy Joined: Dec 2005 Posts: 38 | Thanks everyone for the input, I really appreciate it. I read the thread in the greasy spoon, good stuff, I was looking more along the lines of being able to get a tow dolly from u-haul as a buddy of mine offered to help tow it from the storage unit it is sitting in, back to my home so I can start getting the engine pulled and serviced. I would do it all at the storage unit, but it is 3 hours away.
Is there any difference between a 1/2 ton and a 3/4 ton in the body dimensions, width wise on my '61? U-haul online is telling me that I can't pull a 3/4 ton, but I CAN pull a 1/2 ton. If I trick the system and tell them it's a 1/2 ton, I'm good to go. Thanks again.
- Will
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | According to the restoration package that I ordered from Chevrolet, a 60-66 1/2 ton is 78 3/4 inches wide at the door handles. And a 3/4 ton is also 78 3/4 inches wide at the door handles. The 3/4 ton is going to weigh more than a 1/2 ton because the entire chassis is built with sturdier metal and bigger components to handle the extra weight it can carry. 3/4 ton trucks from that only came with an 8 foot box. Only the 1/2 tons could have the 6 1/2 foot or 8 foot box.
Drew | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Baldy, I didn't mean for him to weigh it "loaded". It sounds like he has to "load" it up to tow it to place to place. Here in the south its interpreted as load it up, take it to the scales and unload and weigh it.  | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | What I meant was that if he has it loaded up, he obviously already has a tow vehicle and has no need to know what it weighs in order to select a tow vehicle, capiche? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | If you just get it runnin'--and stoppin', you won't need to tow it at all! It's way simpler that way. | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | 4 bathroom scales.
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Take it to a truck stop and weigh it,then you will know for sure. | | |
