1 members (Eileen), 99 guests, and 3 robots.
Topics128,079
Posts1,056,310
Members48,442
Stupid question I know, but I am just looking for an approximate so I can figure out what size truck I need to tow it from place to place safely.
1961 C-20, 2x4, Long wheel base I think.
"Remember Who You Are And What You Represent"
"Being responsible sometimes means [censored] people off"
- General Colin Powell
Figure on about 3900-4200 lbs. depending on what bed it has and what other equipment (4-speed,V-8, etc.). Also factor in other thing suchas extra parts that may be included with it. You may consider renting a trailer from U-Haul if you don't have one already, their prices are reasonable. I towed my '55 home frome Geogia with a U-Haul trailer and an '88 3/4 ton K-2500, did fine.
Bill Burmeister
There is a thread in the Greasy Spoon called, "wanna know what your vehicle weighs".... grin
I hope it helps. Beware...several methods are non-conventional eek
MexicoSab wink
Sabrina
'54 3100
I had a 66 once and it was 4400 lb's ,it was 3/4 ton long box ,fleet side. my 53 1/2 ton short stepside box weighs 3400 lbs. Much better mileage, lol.
Once loaded take it to a truck stop and get it "officially" weighed. Should be plenty of place's around your area.
But if he wants to know what it weighs so that he can select a truck to pull it, why would he weigh it after it was loaded?
Thanks everyone for the input, I really appreciate it. I read the thread in the greasy spoon, good stuff, I was looking more along the lines of being able to get a tow dolly from u-haul as a buddy of mine offered to help tow it from the storage unit it is sitting in, back to my home so I can start getting the engine pulled and serviced. I would do it all at the storage unit, but it is 3 hours away.
Is there any difference between a 1/2 ton and a 3/4 ton in the body dimensions, width wise on my '61? U-haul online is telling me that I can't pull a 3/4 ton, but I CAN pull a 1/2 ton. If I trick the system and tell them it's a 1/2 ton, I'm good to go. Thanks again.
- Will
According to the restoration package that I ordered from Chevrolet, a 60-66 1/2 ton is 78 3/4 inches wide at the door handles. And a 3/4 ton is also 78 3/4 inches wide at the door handles. The 3/4 ton is going to weigh more than a 1/2 ton because the entire chassis is built with sturdier metal and bigger components to handle the extra weight it can carry. 3/4 ton trucks from that only came with an 8 foot box. Only the 1/2 tons could have the 6 1/2 foot or 8 foot box.
Drew
Baldy, I didn't mean for him to weigh it "loaded". It sounds like he has to "load" it up to tow it to place to place. Here in the south its interpreted as load it up, take it to the scales and unload and weigh it. grin
What I meant was that if he has it loaded up, he obviously already has a tow vehicle and has no need to know what it weighs in order to select a tow vehicle, capiche?
capiche :p
If you just get it runnin'--and stoppin', you won't need to tow it at all! It's way simpler that way.
4 bathroom scales. grin
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
Take it to a truck stop and weigh it,then you will know for sure.
