10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie), 178 guests, and 3 robots.
Topics128,165
Posts1,056,999
Members48,458
Junior Member
Junior Member
I've bought a sweet one tone dump-truck. Runs well and I having fun geting started restoring. I can't seem to find the orignal rear drums. Can I have the ones on it welded and then machined back to the original 14"? Is there a secret stash out there somewhere? I've tried American Classic and Jim Carter with no luck. Please give me some ideas.
Old Joe
Old Joe,
unfortunately no one makes those drums these days, at least not that I am aware of. I don't think that anyone has come up with a process to add metal, either. Your only source is to find used ones. You could try the swap meet and you could also give Mother Truckers a call.
Another path is to change the brake setup on the back to a more modern setup for which you can buy parts.
1951 1 Ton Completed
Junior Member
Junior Member
' Offline
Old Joe,
Try www.heavychevy.com for your parts. They deal in NOS and used Chevy Parts.
Tony cool
Old Joe, I dug out my '46-'72 Master Parts Catalog.
5.809 Drum Assy. Front and Rear Wheel Brake
'46-'59 1 ton,
'55 Double Duty (2nd Series),
'56-'59 D-D w/14" brake or duals PN#3754313
Hope this will expand your search some. grin
H Online: Content
If a 59 model 3800 has the same brakes, I've got some. Email me!
My "Truck Shop" catalog lists new front and rear brake drums for a '53-'59 3/4 to 1 ton trucks.
www.truckandcarshop.com is their e-address,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
SplashOil,
was that the same drums for front and rear ?
The 1 Ton drums for the 1951 are 14" on the rear and 12" on the Front. I think this may be the same from 1947 to 1952.
Fred, You are correct about the different diameters. I looked in a '54 shop manual which showed 12" front drums and 14" rear drums for one ton trucks. Another consideration is that front and rear shoes may have different widths, hence different drums even with the same diameter.
When I looked in my Canada parts catalogue, I was amazed at the numerous combinations listed depending on axle size, type of tires, production date, serial # sequence, Budd wheels,etc.. I could not find the part # I pulled from the '46-'72 parts book.
I'm not sure if that is because different #'s are used in Canada, or if different parts are used.
I would verify that front and rear drums are also the same width, if they are listed as the same diameter.
Can I make it any more confusing? grin
Splash,
I guess that the design people found creative ways to keep busy, read that employed!
I missed out on one of those Canadian catalogs on Ebay, on the weekend. I got sniped but it was probably out of my budget range anyway!
