4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#208785 05/31/2006 6:22 PM
So I took my 61 on a cross state adventure for memorial day weekend (see story in Greasy Spoon) and everything worked out great but I had to add one thing to my gripe list. My speedometer has always kind of bounced in a 5 mph range on the highway, but now there is a ticking noise that seems to coincide with this bouncing.
What's up with that? Is that the sign of impending doom? Do I need to pull the cable and lube it up? Let it be?
Not sure what to do about it, ideas and thoughts would be greatly appreciated.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#208786 05/31/2006 6:29 PM
you might try lubing it first..........check with popcorn...help may be on the way......
Redryder pix
My Hotrod
#208787 05/31/2006 7:16 PM
Kyle: Try the lube but I bet you got either a gear tooth missing or the little gears might be getting worn thus not making good contact thus the clicking noise.
popcorn The Truth is Out There (Watch out I am becoming a speedometer expert Joker) NOT!!! Pops
#208788 05/31/2006 7:23 PM
make sure to use something like lithium grease to lube that baby up. If you use a penetrating oil you'll end up having to redo it.
#208789 05/31/2006 7:29 PM
It could be the cable broke and intermittently looses its grip at the broken spot and makes a noise when it does. But, lack of lube is usually the reason for problems.
#208790 05/31/2006 9:18 PM
That's what mine was doing after I changed just the broken cable. I then changed the housing and the cable and that took care of the clicking and bouncing. I believe there was a burr or rough spot in the housing. Napa had everything I needed.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#208791 05/31/2006 10:27 PM
Thanks all, I guess I will start with the lube...hope that solves the problem. I am really hoping that it is not a big issue. As always thanks for the input and keep it coming! grin
Kyle
My Machine
#208792 06/01/2006 1:52 AM
Which end of the cable to you take out so that you can lube the cable? My speedo is waving in my '66 C-10 too and I need to lube it, I just don't know how to go about doing it.
Drew
#208793 06/01/2006 2:35 PM
Unscrew the speedo cable from the speedometer. Pull the inner core out. Sometimes there is a small washer on the top end of the cable core. Don't loose it and get it back in place. Look for a nice finished square end (bottom). If the bottom end of the core is freyed and/or broken, remove the bottom end of the cable from the transmission and remove any broken pieces of the core. Look for sharp bends, or stretched parts in the core as well as the outer cable. If your core is broken, try to match up the outer cable with the inner core to see if there is a problem with the outer cable. Obviousely replace a broken core. If the outer cable passes your inspection, grease the inner core and fish it back into the outer cable. Turn the core with your fingers to see if you can feel it binding or catching. If it is reinspect everything. I usually screw the transmission end onto the tranny before sliding the core back in. When the core reaches the transmission gear, turn it either direction until the square end of the core slides into the gear and drops the rest of the way in. Place the speedometer end of the cable/core into the speedometer. If you have to turn the speedo to get the core in, turn the small round brass end on the speedometer until the core slides in. Screw the speedometer side in and that's about it.
#208794 06/01/2006 7:32 PM
builder - thanks for the in depth reply, i am going to try and fix it this weekend.
My Machine
