3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | So I took my 61 on a cross state adventure for memorial day weekend (see story in Greasy Spoon) and everything worked out great but I had to add one thing to my gripe list. My speedometer has always kind of bounced in a 5 mph range on the highway, but now there is a ticking noise that seems to coincide with this bouncing.
What's up with that? Is that the sign of impending doom? Do I need to pull the cable and lube it up? Let it be?
Not sure what to do about it, ideas and thoughts would be greatly appreciated.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might try lubing it first..........check with popcorn...help may be on the way...... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Kyle: Try the lube but I bet you got either a gear tooth missing or the little gears might be getting worn thus not making good contact thus the clicking noise.
popcorn The Truth is Out There (Watch out I am becoming a speedometer expert Joker) NOT!!! Pops | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | make sure to use something like lithium grease to lube that baby up. If you use a penetrating oil you'll end up having to redo it. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | It could be the cable broke and intermittently looses its grip at the broken spot and makes a noise when it does. But, lack of lube is usually the reason for problems. | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | That's what mine was doing after I changed just the broken cable. I then changed the housing and the cable and that took care of the clicking and bouncing. I believe there was a burr or rough spot in the housing. Napa had everything I needed. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Thanks all, I guess I will start with the lube...hope that solves the problem. I am really hoping that it is not a big issue. As always thanks for the input and keep it coming! Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Which end of the cable to you take out so that you can lube the cable? My speedo is waving in my '66 C-10 too and I need to lube it, I just don't know how to go about doing it.
Drew | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Unscrew the speedo cable from the speedometer. Pull the inner core out. Sometimes there is a small washer on the top end of the cable core. Don't loose it and get it back in place. Look for a nice finished square end (bottom). If the bottom end of the core is freyed and/or broken, remove the bottom end of the cable from the transmission and remove any broken pieces of the core. Look for sharp bends, or stretched parts in the core as well as the outer cable. If your core is broken, try to match up the outer cable with the inner core to see if there is a problem with the outer cable. Obviousely replace a broken core. If the outer cable passes your inspection, grease the inner core and fish it back into the outer cable. Turn the core with your fingers to see if you can feel it binding or catching. If it is reinspect everything. I usually screw the transmission end onto the tranny before sliding the core back in. When the core reaches the transmission gear, turn it either direction until the square end of the core slides into the gear and drops the rest of the way in. Place the speedometer end of the cable/core into the speedometer. If you have to turn the speedo to get the core in, turn the small round brass end on the speedometer until the core slides in. Screw the speedometer side in and that's about it. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | builder - thanks for the in depth reply, i am going to try and fix it this weekend.
