1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#208565 05/27/2006 3:22 AM
Junior Member
Junior Member
Well here I go again with another project! This is my first time tackling a 3/4 ton though and need some help on brakes. Has anyone seen or heard of a kit to replace the drums with disc on a 68? If not, how much of a pain is it to swap to 1/2 ton spindles for the front. I can live with rear drum, but shes gonna need a complete brake system overhaul and might as well go with disc. Thanks for any help.
68 C20 Custom Camper
#208566 05/27/2006 3:24 AM
I would think a 72 3/4 ton disc brake set-up would interchange. You'll have to grab the master and the prop valve too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#208567 05/27/2006 3:37 AM
The spindles are probably different between the '68 and the '72. I don't know how easy it would be to swap the spindles, but the entire IFS crossmember can be swapped.
Also there is a kit to put 1/2-ton disks on a 3/4-ton. I don't remember who makes it, but pick up up one of the magazines and I bet you'll find it advertized by someone.
#208568 05/27/2006 3:52 AM
After checking the Moog catalog, I think you could do the conversion just like a 1/2 ton by swapping the knuckles and balljoints. The balljoints are the same from'71-'91 so availability should be ok. The #'s are K6122(upper) and K6129T(lower). You may want to compare the parts in person to verify compatibility.
Bill Burmeister
#208569 05/30/2006 1:02 AM
Junior Member
Junior Member
Looks like I have some research to do. Thanks for the info all, hope I can find the right stuff, these manual brakes lack a little to be desired.
#208570 06/06/2006 11:48 AM
Junior Member
Junior Member
I have 65 C-20 that uses the 73 balljoints bolted to 73 disc spindles that I got from CPP. with upgraded power brakes and a proportioning valve and new tie-rod ends the hardest thing was getting the old balljoints out and the new ones inn. It took me about a day and a buddy to do it. Oh yeah you have to go to the 9/16's lug nuts
Fire in the hole
