| | | Forums66 Topics128,084 Posts1,056,083 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Trying to find rear shocks for my 66 c-30 motorhome.Went to 2 parts stores and rears are not listed for 66 c-30s.They are listed for 67s though.any body know if there the same?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Hmn... ya think they'd be able to order them or something. Have you poked around some shock makers websites? some of them have application guides... or you can pick make, year, model, etc... if that doesn't work, most of them have customer service toll free numbers... some of them even have a email addy for 'will this work' questions. http://www.summitracing.com <- poke around there, it might give you soem ideas. -W | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | '67 is the same. You can also tell them '66 C20 instead of 30. They're the same. -David | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Thanks mugsy.I took it to a service center to see abought getting new u-bolts put on the rear axle and figured i might as well have them put on new shocks while there at it.I just dont feel comfortable jacking it up and working underneath it.I was suprised when they told mee to bring my own parts.Parts store told me to bring in the old shock for mesurment,kinda hard when its still on the truck.Been painting on the outside trying to make it look purdy...altho most folk just think it old.Going on our first trip memorial weekend.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | That's funny. I'm doing the same thing, little body work, little paint, trying to get ready to drive to Paso Robles on Memorial weekend. Hope the shocks work out. -David | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Slow rider...if there is an Advance Auto parts store in your area go to them. If not in stock they can order and have them over-night at a decent price. If need I can get them and then mail them to you!!!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Slow Rider, I checked in the Monroe catalog, there in not a listing for '63-'66 c-30. However, there is a listing for '67-72. It is part #37158. You might also try Sears for Monroe, then it would be part #83623.
Bill Burmeister | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I am pretty sure they were optional on the C30, standard equipment was no shocks on rear. if you can get measurements, a good parts man an look them up thru the specs catalog. brian | | |
