| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | I have a 1953 1 ton flat deck chev.
I am trying to put the parking brake back together - the cement block behind the wheel is getting to be a pain.
I found new cables, and some other parts at Jim Carter. Still missing the strut (spreader bar?) and the pivot arm??? for each side.
Any ideas on where to look for these parts, or a substitute that might work?
Thanks for any help.
Ian Horner
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Before we get too far into this...
Do you have a 53 first series or a 53 second series?
The first series uses Huck Style brakes. The best source for these is a junkyard. AFAIK, nobody makes emergency brake shoe hardware for anyhting bigger than a 1/2 ton anymore. (which really grates my cheese, because I've got a '46 3/4 ton with the same issue).
53 second series has Bendix (AFAIK) and you may (or may not) be able to find that hardware at the various vendors. Have you looked at American Classic and The Parts Supplier Formerly Known As Chevy Duty? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | He has a bar and a pivot BrendanM. That would tell you which era it was.
I wouldn't know where to get one unless you already had one to match too. May have to go to a parts store and start fitting kits to your shoes until something works, Scott | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | i used parts from a 60s chevelle rear end the brake parts worked on a 50 chevy | | |
