6 members (JW51, 55shaker, moparguy, Cosmo, Gdads51, 1 invisible), 108 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#207302 05/08/2006 2:17 AM
Junior Member
Junior Member
I am removing the front clip from my 67. I have removed the top bolts from the rear of the fenders. I have removed the 1 bolt at both rear corners and I have removed the 1 bolt on each of the bottom corners. I have removed the bumper so that the lower splash panel will not hang up. What am I missing? I can not seem to get her to come off. There are two bolts on each corner down by the cab support but I have no idea how to get at the heads as the nut side is facing out.
#207303 05/08/2006 2:30 AM
There's a bolt that connects the inner fenders to the cab. You remove them from the tire side of the fender liner,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#207304 05/08/2006 3:09 AM
Junior Member
Junior Member
Thanks for the help. I was getting frustrated so I had to stop for the day. I will pick it up again tomorrow with my new information.
#207305 05/08/2006 10:52 PM
did you unbolt it from the radiator support? or do you plan on taking that with the front clip.
theres about 4 or 5 bolts on each side, bolting the fenders to the rad support. or, just take the radiator out, and unbolt the rad support, that, coupled with the inner fender bolts, should let you get it all out.
i've messed with alot of fenders...bolts appear out of EVERYWHERE it seems.
good luck!
.later days.
.sam.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
#207306 05/09/2006 4:28 AM
Junior Member
Junior Member
I am leaving the radiator support in and pulling it all as one unit. I had a late appointment or I would be finishing it up tonight. I need to get a move on as I pick up my motor Thursday night.
