3 members (Dennys28, 87GN, 1 invisible),
113
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | im trying to think of something custom to do with my grill. i made a mockup in photoshop of an idea and wanted some opinions. i do not like the mesh in the upper hood but i like the grill. may use a script badge instead of the bowtie. any thoughts? or other ideas? http://img.photobucket.com/albums/v619/theyownus/truck/customgrillideaweb.jpg | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I like the idea, but I don't really like the pattern. It would look better if it was more uniform. I think that it would look good in the grille too, but only if the pattern is changed. The bowite does not look bad, actually I kind of like it. Good concept let us know how it turns out.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I've seen some guys use a vertical row of cabinet door handles all lined up to make some great looking grills. Just a thought. Your idea might look better when finished. Or it might look worse. Just have fun with the effort and sooner or later you will have something you like. Good luck! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm contemplating using a 63 Impala grill on my truck but I haven't found one that I can play with yet. I'm also a long ways from doing custom body work, so that idea is on the back burner for now, Scott | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I don't care for it that much. I think it is too loud. For some reason, I like the dual headlight front ends on that body style of truck. With dual headlights, that grill may look better because the grill area is smaller.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Troy.. you could take a fairly easy way to make it custom.. A bunch of small bits of painters tape and some black is what I used to change it from a checker board to just horizontal bars from headlight to headlight. I'll try and post a picture.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | i had thought about that too. yes post some pics if you get a chance. i'd like to see it | | |
