4 members (Otto Skorzeny, Hanks custodian, JW51, 1 invisible), 48 guests, and 1 robot.
Topics128,054
Posts1,055,780
#207178 05/05/2006 5:33 PM
im trying to think of something custom to do with my grill. i made a mockup in photoshop of an idea and wanted some opinions. i do not like the mesh in the upper hood but i like the grill. may use a script badge instead of the bowtie. any thoughts? or other ideas?
http://img.photobucket.com/albums/v619/theyownus/truck/customgrillideaweb.jpg
#207179 05/05/2006 5:38 PM
I like the idea, but I don't really like the pattern. It would look better if it was more uniform. I think that it would look good in the grille too, but only if the pattern is changed. The bowite does not look bad, actually I kind of like it. Good concept let us know how it turns out.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#207180 05/05/2006 10:22 PM
I've seen some guys use a vertical row of cabinet door handles all lined up to make some great looking grills. Just a thought. Your idea might look better when finished. Or it might look worse. Just have fun with the effort and sooner or later you will have something you like. Good luck!
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#207181 05/06/2006 12:25 AM
I'm contemplating using a 63 Impala grill on my truck but I haven't found one that I can play with yet. I'm also a long ways from doing custom body work, so that idea is on the back burner for now,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#207182 05/08/2006 2:39 PM
I don't care for it that much. I think it is too loud. For some reason, I like the dual headlight front ends on that body style of truck. With dual headlights, that grill may look better because the grill area is smaller.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#207183 05/08/2006 7:11 PM
Troy.. you could take a fairly easy way to make it custom.. A bunch of small bits of painters tape and some black is what I used to change it from a checker board to just horizontal bars from headlight to headlight. I'll try and post a picture.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
#207184 05/08/2006 9:46 PM
i had thought about that too. yes post some pics if you get a chance. i'd like to see it
