| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | I've rebuilt a 350 for my 64 C10, using a lot of smallblock parts off a 283 I got in a 66 bought for parts. I'm using the 283's old ram horns, should I use the heat riser too? How important is the heat riser? | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Make sure its working if you use it. If you're gonna use your truck in the winter, its nice, but not necessary. It theoretically improves mileage and keeps fuel from puddling, too. I'd probably use it if it worked. | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | Thanks 4.3, I guessed it wasn't necessary, just wan't to make sure before I put the exhaust on. | | |
