7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#206557 04/23/2006 7:39 PM
My truck is pretty-much stock and I kinda like it that way. Everyone and their dog has advised me to go for radials. I have 3 original wheels with hub-clips and I've found it very difficult finding tube tires on this side of the border. So, from all of your experience, what should I do? This truck is my daily driver and I just got the kingpins replace last Friday finally. http://members.shaw.ca/magnolia/Stanley-Park2.jpg
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
Mag,
Finding tubes are easy in BC.
Contact any Kal Tire dealer. They can get you some to match the specs of your tire.
I have "radial" tubes on my tires. I am using Firestone bias plys.
I use radial tubes, because the ones I purchased from Coker Tire were too thin. Radial tubes are thicker wall.
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
hey magnolia - check out Yokohama 700x15LT radials [OK tire here] - real truck tires with the right look cool and narrow tread
[also the editors and dial-up users would appreciate you linking that nice pic instead of putting it inline]
Thanks! I went to Fountain tire and they treated me in a very negative tone because I wanted tube-tires and said it would cost $300 per tire for special order. I'm gonna follow-up on your suggestions and hopefully it will work out. My current tires are badly cracked.
Red58, sorry. I've edited the pic.
Photo Album
Hey, go for the radials.
Mag,
After running on 25 year old bias tires with tubes, I just had new radials installed. Wish I did this years ago. Now the truck no longer follows the grooves down the highway and city turning is much nicer. Go radials.
Craig
Junior Member
Junior Member
Yep--I've always run radials--bias ply are only good for the pasture -- my dos pesos smile
Taco
I'll tell you what...
Radials make a heck of a difference in the ride and handling.
I really like mine.
It really depends on where and how fast you drive it. I bought Les Schwab tubes and tires w/highway tread 4 years ago for about $100 per tire(replaced the ORIGINAL tires). They ride just fine. However, now I have an OD and can cruise at 75 and the tires don't cut it at that speed. So now I'm getting radials. If I were only to drive it at a max of 60-65 like before with mostly in town driving I would stick with the original-like tires and tubes because I also like the correct "look". No matter what, radials will make it a smoother ride if that matters to you.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
