1 members (JW51),
115
0
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | My truck is pretty-much stock and I kinda like it that way. Everyone and their dog has advised me to go for radials. I have 3 original wheels with hub-clips and I've found it very difficult finding tube tires on this side of the border. So, from all of your experience, what should I do? This truck is my daily driver and I just got the kingpins replace last Friday finally. http://members.shaw.ca/magnolia/Stanley-Park2.jpg | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Mag,
Finding tubes are easy in BC. Contact any Kal Tire dealer. They can get you some to match the specs of your tire.
I have "radial" tubes on my tires. I am using Firestone bias plys.
I use radial tubes, because the ones I purchased from Coker Tire were too thin. Radial tubes are thicker wall.
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey magnolia - check out Yokohama 700x15LT radials [OK tire here] - real truck tires with the right look  and narrow tread [also the editors and dial-up users would appreciate you linking that nice pic instead of putting it inline] Bill | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | Thanks! I went to Fountain tire and they treated me in a very negative tone because I wanted tube-tires and said it would cost $300 per tire for special order. I'm gonna follow-up on your suggestions and hopefully it will work out. My current tires are badly cracked.
Red58, sorry. I've edited the pic. | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Mag, After running on 25 year old bias tires with tubes, I just had new radials installed. Wish I did this years ago. Now the truck no longer follows the grooves down the highway and city turning is much nicer. Go radials.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | Yep--I've always run radials--bias ply are only good for the pasture -- my dos pesos
Taco
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I'll tell you what...
Radials make a heck of a difference in the ride and handling.
I really like mine. | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | It really depends on where and how fast you drive it. I bought Les Schwab tubes and tires w/highway tread 4 years ago for about $100 per tire(replaced the ORIGINAL tires). They ride just fine. However, now I have an OD and can cruise at 75 and the tires don't cut it at that speed. So now I'm getting radials. If I were only to drive it at a max of 60-65 like before with mostly in town driving I would stick with the original-like tires and tubes because I also like the correct "look". No matter what, radials will make it a smoother ride if that matters to you. | | |
