3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#206557 04/23/2006 7:39 PM
My truck is pretty-much stock and I kinda like it that way. Everyone and their dog has advised me to go for radials. I have 3 original wheels with hub-clips and I've found it very difficult finding tube tires on this side of the border. So, from all of your experience, what should I do? This truck is my daily driver and I just got the kingpins replace last Friday finally. http://members.shaw.ca/magnolia/Stanley-Park2.jpg
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
Mag,
Finding tubes are easy in BC.
Contact any Kal Tire dealer. They can get you some to match the specs of your tire.
I have "radial" tubes on my tires. I am using Firestone bias plys.
I use radial tubes, because the ones I purchased from Coker Tire were too thin. Radial tubes are thicker wall.
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
hey magnolia - check out Yokohama 700x15LT radials [OK tire here] - real truck tires with the right look cool and narrow tread
[also the editors and dial-up users would appreciate you linking that nice pic instead of putting it inline]
Thanks! I went to Fountain tire and they treated me in a very negative tone because I wanted tube-tires and said it would cost $300 per tire for special order. I'm gonna follow-up on your suggestions and hopefully it will work out. My current tires are badly cracked.
Red58, sorry. I've edited the pic.
Photo Album
Hey, go for the radials.
C Online: Content
Mag,
After running on 25 year old bias tires with tubes, I just had new radials installed. Wish I did this years ago. Now the truck no longer follows the grooves down the highway and city turning is much nicer. Go radials.
Craig
Junior Member
Junior Member
Yep--I've always run radials--bias ply are only good for the pasture -- my dos pesos smile
Taco
I'll tell you what...
Radials make a heck of a difference in the ride and handling.
I really like mine.
It really depends on where and how fast you drive it. I bought Les Schwab tubes and tires w/highway tread 4 years ago for about $100 per tire(replaced the ORIGINAL tires). They ride just fine. However, now I have an OD and can cruise at 75 and the tires don't cut it at that speed. So now I'm getting radials. If I were only to drive it at a max of 60-65 like before with mostly in town driving I would stick with the original-like tires and tubes because I also like the correct "look". No matter what, radials will make it a smoother ride if that matters to you.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
