10 members (chevy51truck, Gdads51, Phak1, 52Carl, KEVINSKI, Woodcmiami, Peggy M, Wickedbass, Tinker5, 1 invisible), 40 guests, and 1 robot.
Topics128,036
Posts1,055,458
Members48,422
#206510 04/23/2006 1:21 AM
ok. well just finished hooking up my booster and running new brake lines. got it bled and everything is working... except when i step on the brake pedal it wont return. you have to pull it back out. any ideas? they work great, its just the pedal. i am running the booster off the vacuum line on the front of the carb because there wasnt an outlet on the manifold. could that be the problem? i checked and there is a decent vacuum from the port.
thanks in advance for any help
#206511 04/23/2006 2:23 AM
Unhook the vacuum source and see how it acts. If the diaphram is bad, it could have vacuum on both sides of the booster, hanging things up.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#206512 04/23/2006 2:26 AM
Are you missing the return spring on the pedal? I'm not sure if you need it with the booster, but if so and it's missing you'd have that return problem.
#206513 04/23/2006 4:47 AM
there was no return spring before and it was working fine. actually when the motor is off the pedal does not stick, it will spring back. does that mean the booster is bad? its brand new!
#206514 04/23/2006 1:03 PM
I doubt you have enough vacuum to make it work properly. If you can't get a better line to the booster You might try adding a storage cannister in the line??
#206515 04/23/2006 5:28 PM
Just saw one "remote vacuum reservoir" advertised by performanceonline.com $34.00 If you are running a hot cam, this will effect your problem. Maybe I am over enginering the problem but if you have a small diameter booster you still can put the reservour to good use
#206516 04/24/2006 3:30 AM
looks like there is a port on the intake manifold in the back inbetween the the carb and the dist. cap. will look for that and try that. i would rather not add anything under the hood that is not needed. the sbc has a "RV" cam (so says the PO) so the vacuum should be high enough. from research the booster needs 16 - 23 lbs vacuum. thanks for the info
#206517 04/24/2006 3:01 PM
ok. still no change when using the port off the rear of the intake manifold. is my booster dead??? any other ideas?
thanks in advance
