1 members (Hotrod Lincoln),
163
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 4 Junior Member | | Junior Member Joined: Apr 2006 Posts: 4 | VIN on truck and title say it's a 62, the title itself says it's a 61. How do I find out which is correct? | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | What do the hood and grill look like? How many headlights does it have? If the hood has the "eyebrows" on it and dual headlights, then I would say that you have a 1961. If the hood is the same as the 63-66 trucks and you have single headlights, then the truck is most likely a 1962. Look in the gallery at the differences between the two model years and this might clue you in to what year you have.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | If the hood has nostrils, it's definitely a 61, as Phil says.
On the other hand if it does NOT have nostrils, it COULD still be a 61. Those were so unpopular, that even GM would swap in the new hood when repairing front end damage. The headlights are a safer guide.
Also, back then titles weren't as crucial as they are now. It's possible that you have an early 62 truck which happened to get registered as a '61. Of the VIN plate and the title, the VIN plate is more definitive.
Brian | | | | | Joined: Apr 2006 Posts: 4 Junior Member | | Junior Member Joined: Apr 2006 Posts: 4 | doesnt have nostrils..the Vin on the truck and vin on the title match...model year on the title says 61 but the first digit in the vin is a 2which is reads 62..and the vehicle unit number is fairly low..also has nice spot light not sure if anything like that came original or not..thanks for the responses..guess Ill call it my 61-62 | | | | | Joined: Apr 2006 Posts: 4 Junior Member | | Junior Member Joined: Apr 2006 Posts: 4 | okay I looked at it agian and it does have a small opening at the inside side of the blinker lights on the hood about 1 1/2 in x 12 in | | | | | Joined: Feb 2011 Posts: 42 New Guy | | New Guy Joined: Feb 2011 Posts: 42 | The eyebrows on the '61 are pretty large. They look like huge pods on either side of the hood that stretch all the way back. I'd check the headlights like the guys said and go with the vin if all else fails. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Got me confused, I have a 62 and It has what I would call nostrils on the hood. 2X12 | | | | | Joined: Feb 2011 Posts: 42 New Guy | | New Guy Joined: Feb 2011 Posts: 42 | I'd check the gallery and look at the difference between the 60-61 hoods and the 62-66 hoods. Pretty huge difference if you ask me. The later hoods do have "nostrils" hidden down where the hood meets the radiator support, but the earlier ones have jet intakes on top. Much bigger than 2x12. Hope this helps. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2006 Posts: 4 Junior Member | | Junior Member Joined: Apr 2006 Posts: 4 | thanks joker...looks like the 62 link even the color.. | | |
