2 members (mick53, KEVINSKI), 116 guests, and 2 robots.
Topics128,126
Posts1,056,353
Members48,441
#205846 04/13/2006 6:14 AM
Junior Member
Junior Member
VIN on truck and title say it's a 62, the title itself says it's a 61. How do I find out which is correct?
#205847 04/13/2006 2:43 PM
What do the hood and grill look like? How many headlights does it have? If the hood has the "eyebrows" on it and dual headlights, then I would say that you have a 1961. If the hood is the same as the 63-66 trucks and you have single headlights, then the truck is most likely a 1962. Look in the gallery at the differences between the two model years and this might clue you in to what year you have.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#205848 04/13/2006 4:15 PM
If the hood has nostrils, it's definitely a 61, as Phil says.
On the other hand if it does NOT have nostrils, it COULD still be a 61. Those were so unpopular, that even GM would swap in the new hood when repairing front end damage. The headlights are a safer guide.
Also, back then titles weren't as crucial as they are now. It's possible that you have an early 62 truck which happened to get registered as a '61. Of the VIN plate and the title, the VIN plate is more definitive.
Brian
#205849 04/13/2006 7:38 PM
Junior Member
Junior Member
doesnt have nostrils..the Vin on the truck and vin on the title match...model year on the title says 61 but the first digit in the vin is a 2which is reads 62..and the vehicle unit number is fairly low..also has nice spot light not sure if anything like that came original or not..thanks for the responses..guess Ill call it my 61-62
#205850 04/13/2006 7:44 PM
Junior Member
Junior Member
okay I looked at it agian and it does have a small opening at the inside side of the blinker lights on the hood about 1 1/2 in x 12 in
#205851 04/13/2006 8:08 PM
The eyebrows on the '61 are pretty large. They look like huge pods on either side of the hood that stretch all the way back. I'd check the headlights like the guys said and go with the vin if all else fails.
#205852 04/13/2006 8:18 PM
Got me confused, I have a 62 and It has what I would call nostrils on the hood. 2X12
#205853 04/13/2006 10:28 PM
I'd check the gallery and look at the difference between the 60-61 hoods and the 62-66 hoods. Pretty huge difference if you ask me. The later hoods do have "nostrils" hidden down where the hood meets the radiator support, but the earlier ones have jet intakes on top. Much bigger than 2x12. Hope this helps.
#205854 04/13/2006 10:37 PM
Redryder pix
My Hotrod
#205855 04/13/2006 10:43 PM
Redryder pix
My Hotrod
#205856 04/14/2006 1:21 AM
Junior Member
Junior Member
thanks joker...looks like the 62 link even the color..
