2 members (J Lucas, JW51), 266 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
#204724 03/26/2006 8:59 PM
well not that race...
1958 1/2 ton. front axle,
the race on the axle spins,,, what should i do?
ping the axle to make it snug?
any sugestions would be greatly appreciated
#204725 03/26/2006 9:10 PM
3B Offline
Hy 59 gmc., I presume we're talking about the inner bearing, just how loose is it, it does have to slide on and off the spindle to be installed and removed. Does the spindle look all galled up or does it look okay?
#204726 03/26/2006 11:24 PM
spindle looks finr but the race was hard to remove for clean up,i am restoring this thing bolt by bolt everything is getting sandblasted or cleaned up with a wire brush and repainted,
so with that said; i removed the assembly and lightly cleaned the spindle with emery cloth, and the inner race is loose ,so my thought was to ping it at 4 places,using a drill punch and tap the bearing race on,,sounds logical but i have made mistakes at least once before grin
#204727 03/27/2006 2:54 AM
are you saying that you are reusing the original race. if you are then your supposed to replace those, i thought, but tell me if i am completely wrong. if you do replace them then just buy a new bearing and race set.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
#204728 03/27/2006 4:24 AM
3B Offline
Hy 59 gmc., I don't like the description "loose", was there a rust buildup when you removed the bearing? The bearing should be snug, not so tight that you have to use a hammer and punch to install it.
#204729 03/27/2006 7:49 AM
If it has not spun on the spindle it's not too loose. It should slide on with your hand, not be driven on. If your antsy about it use some "bearing lock" by Locktite or others. You will have to warm it to get it back off but not heat it enough to discolor it.
Evan
#204730 03/27/2006 4:39 PM
It seems that the inner race on ball bearings are usually snug on the axle. If you were replacing them I would hope and suggest that you are going to tappered roller bearings. The bearing should slide right over the axle. The inner race is a part of the bearing on a tappered bearing.
#204731 03/27/2006 5:32 PM
Don't damage the spindle with a punch. Loctite makes great products to keep the race still. Just put a little so it doesn't get into the bearing. Here's a link.
http://www.loctite.com/int_henkel/loctite_us/index.cfm?&pageid=130&layout=1
You Tube
#204732 03/27/2006 5:34 PM
Sorry, not enough info in that link. Click on retaining and then on 609. Good luck.
You Tube
#204733 03/27/2006 5:39 PM
thanks guys..new i could count on the fellas from stove bolt...i will pick up new races and bearings this week when i head to the city, grin
