2 members (IHPWR, Otto Skorzeny), 147 guests, and 1 robot.
Topics128,157
Posts1,056,878
Members48,458
Junior Member
Junior Member
Guys,
I am about to start putting my '48 back together. I am looking for the Quad set gauge, and speedo. Does anyone make gauges that fit in the factory opening, or will I have to use adapters? I've done lots of research, and come up with very little. What did you guys use? Post pics if you can.
Mark
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
In my 48 chev I put in Auto Meter guages from Summit I had to do a little adapting to make them fit. Boy they sure look good when their mounted in the dash.
38 original
48 panel
59 stepside
46 in the back forty
I have heard that the gauges from a Toyota truck(model unknown) will fit. Seems they are set up in two clusters like the stock Chevy ones.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Check out haneline.com. They will have what you need.
George
check out dolphin guages ( http://www.dolphingauges.com/ ). I cant speak of the quality personally but the price is right...
also thats whats was used in Alans detailed writeup here: http://alanhorvath.com/54chevy/dolphingauges.php
good luck!
Try www.dakotadigital.com
They make some of the nicest digital guages.
I have Autometer gauges in my 57 with an aluminum insert and orginal bezel. They look great and are electronic. That way I can calibrate my speedo with 1 touch of a button and it will always be correct. They dont have a mechanical speedo cable they have an electric impulse cable that transfers the info from the trans to the speedo. The best part is these electric speedos and guages will work on all cars and trucks and give accurate info to the driver.
try Haneline
@ $399.99 for the two.
http://www.haneline.com/chevytrks.html
Jim & Caroline
