| | | Forums66 Topics128,141 Posts1,056,780 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 15 Junior Member | | Junior Member Joined: Apr 2005 Posts: 15 | Guys, I am about to start putting my '48 back together. I am looking for the Quad set gauge, and speedo. Does anyone make gauges that fit in the factory opening, or will I have to use adapters? I've done lots of research, and come up with very little. What did you guys use? Post pics if you can.
Thanks, Mark | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | In my 48 chev I put in Auto Meter guages from Summit I had to do a little adapting to make them fit. Boy they sure look good when their mounted in the dash.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have heard that the gauges from a Toyota truck(model unknown) will fit. Seems they are set up in two clusters like the stock Chevy ones. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Check out haneline.com. They will have what you need. George | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Try www.dakotadigital.com They make some of the nicest digital guages. | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | I have Autometer gauges in my 57 with an aluminum insert and orginal bezel. They look great and are electronic. That way I can calibrate my speedo with 1 touch of a button and it will always be correct. They dont have a mechanical speedo cable they have an electric impulse cable that transfers the info from the trans to the speedo. The best part is these electric speedos and guages will work on all cars and trucks and give accurate info to the driver. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
