0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I have bled these dang brakes till the wifes leg gave out and it still takes 2 pumps to get pedal.Ive added speed bleeders to the rear went around the wheels again farthest to closest and still the same.wHAT AM I MISSING? On the second pump the pedal is hard and holds..
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You must not have the shoes adjusted all the way out. Or maybe a wheel cylinder piston rod is not in the shoe. Adjust each wheel till you get a heavy drag. Than back off 3-4 notches. If thats not it pull the drums & make shure everything is in correctly. You will have to take good wife out to dinner after this is done. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | After you get the brake shoes done, you may have to adjust the pedal rod, especially if you had any of that apart or loose, Scott | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I havent had any of it apart yet.THE P.O. told me that they worked fine untill he broke and replaced one of the brake lines.I drove it abought 25o mile home and the brakes are good on the 2nd pump but go to the floor on the first.The vacume asist wouldnd cause this would it?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Sounds like a Volume problem. Sure you have right bore size on Master? That's how mine acted on a truck with too small of Master. Are you aware the Hydro-vac needs bleeding also? Sometimes two bleeders on them. These big trucks, have dual rear cylinders, and are hard to get air from one's in back, because of their position and only one bleeder on one cylinder. Sometimes you need to jack up truck or release brake line nuts to bleed those. There is an article in last months Vintage Truck magazine about bleeding the older rigs. I believe it is better to bleed the master, the hydro next, then the CLOSEST, shortest wheel line in front, then other front, and follow rear lines back, do the one nearest frame with line on it, Then do the last farther away one. My idea is that you are following the fluid around system as you go, each time getting air farther down system. Does your hydro-vac work? Should be difference in how brakes work when running truck and when off. Sometimes, the force of hydro works the air down system easier. Look at those rear cylinders, bet that's the problem.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Hey Slow..Rider, you ever get that 42 done yet??
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I agree with Wrenchbender; You probably need to adjust your brakes. chances are they worked like this before the line was replaced. Speed | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Chriss $till workin on it.I bled them twice saterday laying in 4 inches of very cold water.Sunday i pulled it out on the dry road.Today we got 23 inches of snow so itl be awhile before i can get back at it.G.L.THANKS,ill try that when i can get back to it.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | If you pulled a length of brake line off, it will take several attempts to get all the air bled out. Here's a procedure I wrote down when I was younger... 1-have assistant pump brakes 1/2 way down several times (~15 seconds) 2-press and hold the brakes firmly 3-open bleeder screw for a few seconds, then close up again 4-release brake pedal 5-WAIT 15 seconds 6-repeat steps 1-5 at all four tires until ALL the air is out! P.S. Don;t forget to keep an eye on the fluid in the master cylinder. if it gets too low, you will be introducing air into the lines again Dano
my truck gets better every day...every PAYDAY | | |
