| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Does anyone know where I can get new lead gaskets for my single action shocks? The gaskets, more like a washer I guess, go around the fill/drain plugs. I've taken all four apart and cleaned them up really good. The service manual recommends using new ones.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if they look like you could cut them yourself, find an old plumbing roof vent flashing and fly at it! lead cuts pretty easy, and hole punches would do a neat job
Bill | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | We use lead washers on chlorinators at the water and waste water plants. i'm at home and don't have the size, but they are about 1/2" hole and 3/4 out side dia. cand send you some if you think they will fit.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | go to a plumming supply house and buy the material. them make them. they don't have to be perfect. You can make a hole punch by grinding down a piece of pipe the proper size and whack it with a hammer. lead cuts easily. | | |
