4 members (HandyAndy, Phak1, Otto Skorzeny, mo2cyl), 89 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#203216 03/08/2006 7:42 PM
Does anyone know where I can get new lead gaskets for my single action shocks? The gaskets, more like a washer I guess, go around the fill/drain plugs. I've taken all four apart and cleaned them up really good. The service manual recommends using new ones.
Neil
1940 GMC 1/2 Ton
#203217 03/08/2006 8:30 PM
if they look like you could cut them yourself, find an old plumbing roof vent flashing and fly at it! lead cuts pretty easy, and hole punches would do a neat job
#203218 03/09/2006 11:02 PM
We use lead washers on chlorinators at the water and waste water plants. i'm at home and don't have the size, but they are about 1/2" hole and 3/4 out side dia. cand send you some if you think they will fit.
"It ain't a truck if you can't hose out the cab."
#203219 03/09/2006 11:08 PM
go to a plumming supply house and buy the material. them make them. they don't have to be perfect. You can make a hole punch by grinding down a piece of pipe the proper size and whack it with a hammer. lead cuts easily.
