1 members (Hotrod Lincoln),
92
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 21 Apprentice | | Apprentice Joined: Feb 2006 Posts: 21 | I am still having problem as stated in my previous post, Indiana to Ohio vin problem. Tille has engine number on it and doesn't match the vin number on door plate. I checked here in Ohio and no luck yet. Does anyone know where I can find the Vin number on the frame? Thanks in advance, Ralph | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The door number shouldn't match the engine. I don't think there was a frame number, but I got my 53 registered using the number on the door serial plate. DMV just needs a number that is currently not in use. Id contact a street rod shop or try to find a DMV person that works for used car lots, these people deal with these issues every day and know the ropes. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | The folks down at AAA usually have someone who deals with registrations and know the ropes for older trucks. Give the local office a call of visit.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well you have a couple of problems here.
First is that VIN has a special meaning and wasn't in use in 1953. Your truck does not and never had a VIN.
Second is that they never put a serial number on the frame in 1953.
I don't know the solution to this problem but when dealing with the state you may have to educate them about these details. Most likely you are dealing with someone who wasn't even born when you truck was built...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
