| | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | hey i have a 1951 3800 and i want to know if it is leaded or nonleaded... also i her that in 1951 they didnt make 3800 1ton they only made 3600 series pleas help me. and if nebody has front and rear fenders that will fit hit me up either here or on my email [email protected]thankyou for your time | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Depending upon how old the valves and seats are -- and what type they are -- you may or may not.
If they are old, they are probably the original type. If it ran leaded for most of that time, you should be fine with unleaded. The lead from the gas has permeated the seats.
If they're new(ish) and the original type, then yes. Put a leaded additive in the tank.
If they're the new hardened type, then you will be fine with unleaded. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my experience is unless you're running the engine unusually hard or hot, you won't have a problem in the life of the engine - I'm running a 235 that's never been opened up and after about 30,000 miles on modern fuel it's fine - see many others do the same as for the model, see what your VIN says and check here - the 3600 would be different wheelbase than the 3800 Bill | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I'm with red58. My experience with early engines is the hype about burning valves & damaging valve seats is just that - hype. I've put tons of miles on pre unleaded engines and have never had a problem. I put over 100K on a pre unleaded 235 and over 50K on a pre unleaded Harley using unleaded gas without problems. I'm working on my 38 now without putting in hardened seats & valves.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Auto suplies have "lead" substitute, the hose brands are cheep. and it only takes an oz to 5 gal, you can sleep beter at night.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | That is house brands, sorry.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have used a few ounces of Marvel Mystery Oil per tank in all my old iron for years.My friend uses two cycle oil(weed wacker,chain saw)in his old cars and trucks.It doesn't take much to lube the valve seats and stems.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | note that the problem w/ unleaded and old vehicles is recession of the valve seats - hence the seats are replaced w/ hardened ones - doesn't really have anything to do w/ the valves themselves unless you're drag racing or pulling a heavy load constantly that causes extreme heat [like where the exhaust starts to get red], there's NO problem running unleaded in an engine without hardened seats here's what Chevron had to say about it after tetra-ethyl lead was banned Bill | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | When I was a kid we used to buy old crappy cars we'd find sitting in peoples lawns, beside their houses with grass growing up past the windows.. heck, sometimes they'd just give the cars to us. We'd quite unsafely strap a few chains to 'em and drag 'em home and wrench on them for hours to get them running.. then sell them.. it was fun for a 16 year old kids.. and got us a little extra spending cash. Anyway.. one of these cars we got for free was a real crap heap.. the local gas station sold this stuff called Turbo Blue.. some crazy high octane fuel.. we put a few gallons of that in the tank for its final drive to the local bone yard. First mile or so that thing screamed like a raped ape.. then it started clangin' and bangin' and shreikin'... then came the smoke... Lesson learned: Use the kind of fuel your engine was designed to run! With that said.. I run regular unleaded gas in everything I own.. from the weedwacker to the daily drivers with no problem. They don't sell Turbo Blue around here.. so it's not a temptation!
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Speaking of octane ratings, we have a fleet of Cadillac limousines and coaches. They all say "Use Premium Fuel Only" on the gas tank flap but every so often I put in regular grade gas and no one has yet had a problem or felt anything strange or even heard pinging. | | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | As far as 51 3800 1 tons not being built, that's not true, I just found a 51 3800 1 ton with the extra long bed. I checked the VIN, before I traded for it. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | hey, red58, thanks for that link. i'm going to save that.
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | |
