7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
92
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | The stamp on the inside of the door says 5000 on a 1/2t longbox. I'm tempted to get an Avion truck camper but not sure if my truck will do ok with 2000 lbs truck camper c-10. The other option would be to have a canopy and a small trailer of the same age. Original 235 engine works fine with the exception of warm-start trouble.
I need to use it for buying trees & shrubs in California and somewhere to stay while I shop-around. Any thoughts, suggestions? Thanks. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | A 1/2 ton truck is a bit light for a slide in camper. The half ton designation means you can carry up to 1,000 lbs. If your slide-in is 2,000 lbs they that would be a no go. Most use a 3/4 or 1 ton for that service depending on the size of the slide-in. The small trailer would be a good route as it leaves the bed available for haulling. | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Remeber, your GVW is the gross vehicle weight, meaning the truck, fluids, you, passengers AND cargo. I'd go with a period topper and pull a small camper behind.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The tongue weight of the trailer needs to be included in the GVW. I'd suggest upgrading to disk brakes on the front before pulling is serious weight. IMHO the 1/2 ton brakes are barely good enough to stop an unloaded truck. That's why I've always bought 3/4 ton. Larry
I don't own a vehicle that isn't old enough to drink. | | |
