1 members (Hotrod Lincoln), 69 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
The stamp on the inside of the door says 5000 on a 1/2t longbox. I'm tempted to get an Avion truck camper but not sure if my truck will do ok with 2000 lbs truck camper c-10. The other option would be to have a canopy and a small trailer of the same age. Original 235 engine works fine with the exception of warm-start trouble.
I need to use it for buying trees & shrubs in California and somewhere to stay while I shop-around. Any thoughts, suggestions? Thanks.
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
Anonymous
Unregistered
Anonymous
Unregistered
A 1/2 ton truck is a bit light for a slide in camper. The half ton designation means you can carry up to 1,000 lbs. If your slide-in is 2,000 lbs they that would be a no go. Most use a 3/4 or 1 ton for that service depending on the size of the slide-in. The small trailer would be a good route as it leaves the bed available for haulling.
Remeber, your GVW is the gross vehicle weight, meaning the truck, fluids, you, passengers AND cargo. I'd go with a period topper and pull a small camper behind.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
The tongue weight of the trailer needs to be included in the GVW. I'd suggest upgrading to disk brakes on the front before pulling is serious weight. IMHO the 1/2 ton brakes are barely good enough to stop an unloaded truck. That's why I've always bought 3/4 ton.
Larry
I don't own a vehicle that isn't old enough to drink.
