5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#201655 02/19/2006 9:36 PM
Ok so i am not mechanically inclined. I need help. I have dual exhaust on my 64 chevy 1/2 ton. It is smokin from the right exhaust pipe. the smoke is not black. Looks more like white smoke. ANy clue on wat it might be?
Stovebolt-It is painted
#201656 02/19/2006 9:58 PM
I only assume you have a V8. I also assume you have a blown head gasket or a broken head on that side and what you see is coolant. check your radiator level.
#201657 02/19/2006 10:53 PM
Sounds like a gasket or a crack to me to. Check your oil as well some times the coolant go to the pan. and check your spark plugs for moister on the side thats blowing white.
New deal for old steel
#201658 02/20/2006 1:17 AM
Does it do this all the time or just when it's cold out side. If just dose this when it's cold could be the heat riser doing it's job. It should stop when the motor comes up to full temp.
#201659 02/20/2006 1:17 AM
Oh sorry it is a v8 350 auto. Hmm ok guys thanks i will check it out again.
#201660 02/20/2006 3:00 AM
Black Smoke-Too Rich
White smoke-Water
Blue smoke-bad news-oil
#201661 02/20/2006 8:47 AM
I am going to agree with the head gasket guys. WHite smoke does mean water and the fact that it is coming out of one side makes it even more suspicous. I would check the oil for coolant and check the coolant level. I hope that you get it figured out with a minumum of effort and worry.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#201662 02/20/2006 5:02 PM
yea I hope it isnt as bad as i think. I dont know now the smoke looks either white or blue..not sure it like in between right now. Thanks again guys
#201663 02/21/2006 5:24 AM
im gonna say its a head gasket. thats what i learned white smoke usually meant.
red (mostly) 1963 chevy shortbed stepside
#201664 02/22/2006 6:15 PM
If it is white and has a sweet smell, it is coolant. You should be losing water from the system if so. Also check for water in the oil or oil in the radiator. It will appear milk like. The best way to find out is have your system pressure tested and also check the engine compression. Good luck resolving the problem.
Heres to us and those like us, theres darn few left.
#201665 02/23/2006 4:14 AM
A quick way to check if you have a gasket problem is to pull the plugs on the right side of the engine if you have water on the plugs you have a leak somewhere, while you have the plugs out have someone crank the engine(pull the coil wire first) if there water in a cylinder it will come out fast(be sure to wear eye protection). Coolant in the oil is bad for the bearins.
#201666 02/23/2006 8:50 PM
long time ago but i had the same problems with a 283 and unfortunately it was a crack in the head on that side but i hope for your sake it is just a gasket.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#201667 02/24/2006 5:18 PM
White smoke is water.
Blue smoke is oil.
Black smoke is gas.
