4 members (cmayna, EddieD, 2 invisible),
47
Mod | | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | A neighbor of mine with a late '60's Chevy pickup is hunting for a stop light switch.
He told me it isn't a mechanical switch, but hydraulically actuated switch on the master cylinder. Did Chevrolet ever use a switch like this..I have NEVER heard of it?
Stuart | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | He doesn't need a switch for any paticular brand as long as it's for 12 volts. Most all had 1/8" NPT threads but a few had 1/4". Just get one with the same threads and screw it in. He may have to put the wire terminals on that fit the switch if differant from the present one.
Evan
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Coilover is basically correct except for the voltage. A switch is a switch is a switch and in most cases doesn't care what the voltage is. I've seen many "12volt" switches have 120v or 240v capacities stamped on them. The brakelight switch on my 38 looks exactly like the one pictured in the middle here: http://www.chevsofthe40s.com/search.lasso?&dept=truck&cat=180T&skip=140&Max=20 Scroll to the bottom of the page. It does show a mechanical switch on the right for later models though.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The 60-66 trucks had an electric brake light switch mounted on the column but you can put an inline pressure switch in it's place. Most parts houses carry them or can get them. Just need to know the size of your brake lines, Scott | | |
