Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (WICruiser, Joe H), 148 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#201644 02/19/2006 5:44 PM
A neighbor of mine with a late '60's Chevy pickup is hunting for a stop light switch.
He told me it isn't a mechanical switch, but hydraulically actuated switch on the master cylinder. Did Chevrolet ever use a switch like this..I have NEVER heard of it?
Stuart
#201645 02/19/2006 6:52 PM
He doesn't need a switch for any paticular brand as long as it's for 12 volts. Most all had 1/8" NPT threads but a few had 1/4". Just get one with the same threads and screw it in. He may have to put the wire terminals on that fit the switch if differant from the present one.
Evan
#201646 02/19/2006 7:53 PM
Ex Hall Monitor
Ex Hall Monitor
Coilover is basically correct except for the voltage. A switch is a switch is a switch and in most cases doesn't care what the voltage is. I've seen many "12volt" switches have 120v or 240v capacities stamped on them.
The brakelight switch on my 38 looks exactly like the one pictured in the middle here: http://www.chevsofthe40s.com/search.lasso?&dept=truck&cat=180T&skip=140&Max=20
Scroll to the bottom of the page. It does show a mechanical switch on the right for later models though.
#201647 02/19/2006 8:20 PM
The 60-66 trucks had an electric brake light switch mounted on the column but you can put an inline pressure switch in it's place. Most parts houses carry them or can get them. Just need to know the size of your brake lines,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
