| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | [From Brad54 in another thread: ...The doors have the typical hyperextension dents.]
My 66 has this also. How common is this? It seems that it could be reasonably repaired without replacing the door panel. Opinions?
[Edit] Also, anyone already have a solution to preventing again in the future?
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | To prevent them, you only need to replace the door stays. Most vendors carry them. To repair them, usually depends on how bad they are. I've welded pins onto the low side of the dent and work them back out with a slide hammer. If they aren't very bad, you can work them out from the inside with an old ax handle or something of the like. Scott | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | I did the pin welder/slide hammer thing, worked very well.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Yep, we did the (screw-type) slide hammer method as well, with a light icing of fiberglass body filler. I'd say it is an extremely common problem. | | |
