1 members (classicchevs), 101 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
#200314 02/06/2006 8:31 PM
Hi and another question from KANADIAN KORNER.
My '50 didn't come with a heater although I can detect a faint outline of something that was mounted inside the cab where 2 existing holes are that would probably fit heater hoses. My question is : what heaters will fit my truck as in other years ? .Thanks. This is a great site.
#200315 02/06/2006 8:35 PM
Riding in the Passing Lane
1947 to 1953 will be a direct fit. I believe there was a standard & deluxe. Many of these old trucks & cars had aftermarket heaters. One of those could be easily installed.
1972 Chevy c10 Cheyenne Super
#200316 02/07/2006 6:57 AM
If you want a dealer on the Canadian side try Iron Chief. I thought his price was reasonable. Cecil..........
#200317 02/07/2006 7:13 AM
I have the standard heater in my 49. The core is made circular and in two pieces with a hole in the center like a donut. The fan motor mounts in the center of the hole. The two tubes go thru the firewall from the inside and there are 3 mounting bolt holes in the firewall if it is a standard. There is also a flat plate about 4" in diameter on the firewall in that location. I think that it has to do with the deluxe heater. These heaters occasionally show up on eBay but you should be able to find one elsewhere. If you need more help you can email me.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
