7 members (JW51, Hotrod Lincoln, Wally / Montana, texas46, TooMany2count, Jaison, 1 invisible),
120
Mod | | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Hi Everyone I am restring my 48 3100 shortbox. I am lowering it alittle. The front and back will be approx. 8" off the ground.
My question is without spending $500. for a fuel cell, what are my options for a gas tank that fits in between the rear frame rails...
Thanks for the help Tom
48 Chevy 3100 Shortbox 5 window "The Big Dog"
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | do a search this topic has been talked about quit a bit. the short answer is yes
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | if you do , which a lot have, and you get hit from behind, you might think that your are drivin a crown vic..  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | That's great. I did a search and still didn't get an answer. Thanks
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | sup tomy, I used a 67-69 ford mustang tank then built a frame out of 1in sq. tubing. you'll have to modify the rear cross member and box it in but it really worked great. send me your e-mail and i'll send you pics. [email protected] | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Hi, Tomy2,
I decided to do the same thing in an economical manner for my '59 Apache. What I did was look up gas tanks in the J. C. Whitney catalog. I found a general tank type I thought would work, then contacted JCW customer service to get dimensions. The customer service people were very cooperative and supplied me with all the info I needed about several gas tanks. I ordered a 25 gallon steel tank (they had plastic ones as well) and it turned out to be just as described. I think I paid under $150, so was quite happy with the results. Apache | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | A65 Mustang will fit perfect on the back rails
dan-pa
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | do a search on ''under bed gas tanks''. Ours is set just like a 48 under bed tank, filler on the side!!!! ours is inside the frame, passenger side, in front of the rear axle. Had to cut that small triangled sheet steel out to make it clear to fit higher. Used the old filler but extended the tube to accept a 2'' gas hose and attached the filler to the outside wall of the bed just below the wood bed. It has an anti-roll vent. No rear enders for us !! accident fires and rear end tanks! Side fill like the 1948's http://s67.photobucket.com/albums/h298/1951otter/ you'll have to scroll down the page after you open the link ... forget the logon bit at the top. The tank is from tanks inc. a universal 16 gal e/w anti roll valve. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=002404#000006 try these
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | The only problem with the mustang tank is the sending unit is for a positive ground and GM uses a negative ground system. Or is it the other way around? Either way your sending unit will not function correctly if you use the standard ford unit. Other than that the early mustang tank(68-69 is the best bet for larger capacity) is a good way to go. I used an 18 gal 1st generation camaro tank | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | I like the way the ford gas tank mounts. Does the 1st gen Camaros tank look the same?
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | my 1 ton gmc flatbed has the tank inside the frame rales and just behind the cab. wonder if one out of a flatbed would work in the same place as the flatbed has them.... :confused: | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | that makes a big differance. Can a person make a chevy sending unit work in a ford tank?
Tom
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | What happened to your 48 tank? 47 and 48 were the two years that AD trucks had frame mounted tanks, in 49 they went in the cab. The fuel filler tube on a 48 comes through the very bottom of the bed on the passenger side just above the filler panel at the rear of the running board, and held about 16 gallons. Correction on an earlier post on this subject: ford has not had positve ground since 1955 but their sender signal is backwad to GM's 0-90 ohm signal. Your gas guage will work but full will be empty and visa-versa with a mustang tank.
Evan
| | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | My gas tank was missing when I bought the truck. I would like to place my tank in the back of the truck, with a flush mount filler neck.
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey Apache, did JC have a plastic tank to fit in place of original '48 chevy. I have the original but instead of going thru the trouble of beating the old gas and rust scales and ol gas of 50 some years, thought I would try to find one in plastic to fit its place! Thanx ,bowtie | | | | | Joined: Dec 2005 Posts: 6 Junior Member | | Junior Member Joined: Dec 2005 Posts: 6 | Tomy2tone01, I can tell yuo that a 1987 Toyota 1/2 ton tank is a perfect fit. I have installed a 76 Jag XJ6 rear end in my 49 chev and the gas tank sits between it and the last crossmember. It goes between the frame rails really nicely. | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Hwymen49 Sounds good but what about the sending unit? Tom
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | another option is 83 el camino which already has sending unit.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2005 Posts: 9 Junior Member | | Junior Member Joined: May 2005 Posts: 9 | Hi there, I'm at the same cross roads. I'm restoring a 1950 3100 P/U and got some issues on where to place the filler neck. Any of these tanks going to work for me if I put filler tank out throught sheet metal in the side of box, behind rear drivers wheel.??????? | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | SADDLE TANK?
Has anyone thought about a saddle tank?
You know, one that goes above the driveshaft, below the bed, behind the tranny and between the rails?
I've seen one or two in the junk yards but can't remember what they were under.
| | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Saddle tanks sound like Ford or International. I am going up to the yard this week end might be a good reason to snoop around.
Tom
| | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 |
New deal for old steel
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I saw a thread with a link to a site with pictures of the guy installing the tank on the passanger side, like the '49, and running the filler neck to the rear fender and putting a 'door' there. It looked nice when it was done, but not stock.
I wonder if you could put a tank along the frame rail on the passangers side and ran a hose/pipe into the cab and up to the original filler neck. The pipe/hose might come in the inner cab corner and up and use a grommet similar to the one used on the filler neck, the pipe/hose and filler neck could probably remain behind a panel.
Just a thought!
| | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | http://community.webshots.com/mypho...mp;albumID=491369445&security=OSysPm Here's a link to some pics of my 53 project. the gas tank is behind the rear end housing and the filler neck is hidden in the middle behind the pull down license plate holder. A little modification was done to shorten the neck, but it's all nicely tucked away out of site now. resto44 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to my community webshots at the bottom of this post, pics. of my 54 install. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Hey, Bowtie, If you don't have a JCW catalog, you can go to: http://www.jcwhitney.com/autoparts/...tank&searchbtn.x=7&searchbtn.y=6 and have a look around. Have a look at P/N WK070065. I also think there's a plastic version of the steel tank P/N WK862180. I got the steel version, and am installing it right now. It measures (from memory) about 29" X 29" X 9" deep, which fits between my '59 frame rails fine. I have it as far forward as possible for safety reasons. There's about 17" distance between the back of the tank and the fron to the rear bumper (but then it's a Fleetline bed). I'm using rubber hose to keep a flexible link to avoid making any sparks. You can get a universal sending unit for Ford/Chevy/Stewart-Warner at JCP. P/N WK132950 for GM vehicles with 0 - 90 ohms resistance. Regards, Apache Kid | | |
